Answering Crownarch
PM doesn't accommodate pictures...
A picture is worth.... ![]() Left is Nostalgic Binary switch, right is Red Dot RD-5-4585-0 Nostalgic's opens the compressor clutch at 398 PSI, 'way to high for our A/C systems. Red Dot at 325 PSI will still be pushing the "limit". Last edited by wwest; 05-22-2014 at 12:46 PM.. |
Nostalgic R-134a adapter w/pressure switch port/fitting.
Fleabit peanut monkey
Can this or alternate be used with my 81's R-12? I still have a stash of the good stuff left.
1981 911SC Targa |
Best friend is my dog
Thanks wwest. Same set up I am using with the Red Dot trinary switch. After digging through my stash of bits, I had grabbed the wrong switch and yes the threads on the R5-4585-0 threads are the same as the ones on the Nostalgic. I just wish the my Red Dot electric plug wasn't so large.
So, I assume you are wiring the Red Dot in as same as you would with the Nostalgic. |
