Unhappy removing oil cap
1987 porsche carrera
when I remove the oil cap at correct idle of 880, the idle stays the same.
My understanding is that i have a vaccum leak...
I recently changed my rear shocks and removed the airbox cover, one breather hose (i re installed it) and hung the large black rubber hoses to provide some space...
Where should I look for it?
Old 05-14-2014, 08:47 AM
Brew Master
cabmandone's Avatar
I was told to check the hoses that run to the oil tank and check the boot on the intake. I guess the boots over time will develop small cracks that allow air in.
Old 05-14-2014, 08:48 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Spray some Quick Start spray (Motomaster @ Cdn Tire) around hose joint and the like.
If the revs go up, you found your leak(s).
Who Will Live... Will See
Old 05-14-2014, 09:32 AM
muck-raker
kidrock's Avatar
There are also 2 small hoses that connect to a valve on the back of the throttle body, IIRC. Very common for these to become disconnected.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-14-2014, 09:51 AM
