-   -   Steering getting heavier? (http://forums.pelicanparts.com/porsche-911-technical-forum/811348-steering-getting-heavier.html)
Weaver 05-15-2014 09:59 AM
Or am I getting weaker!
My steering seems to be getting heavier, less lively, than before. It seems gradual, not all at once. And maybe its me….I'm not sure, but I'm starting to worry a little. Here are the car specs:
'88 Targa
89K miles
lowered to Euro spec
Original stock struts
Aligned by very reputable Midwest Porsche shop
Corner balanced to 30 lbs. LF weight with driver weight and full tanks
Caster is +5.8 and +6.0 L to R respectively
Camber is -1.0 and -1.1 L to R respectively
Toe is +.12 both sides
Turbo tie rods
Bump steer kit
7s & 9s Fuchs
205/55/16 & 245/45/16
Michelin Pilot Sport Cup tires, F 3/32" R 0/32"
I need to put it on jack stands and turn the wheel lock to lock, see if I can feel or hear anything.
Anyone have suggestion on what to check? Maybe just do some pushups!?!
Thank you for your time.
TheSt|G 05-15-2014 10:52 AM
Pilot Cups certainly won't make steering easy.
javadog 05-15-2014 11:57 AM
Check your tire pressures.
db_cooper 05-15-2014 12:19 PM
Second that on the tire pressures. And..do check your front wheel bearings. Just just did a full brake job with new wheel bearings. The original bearings were still there..and have been repacked sometime in the past..looked fine, and not too loose.
Steering effort was greatly reduced and improved after the work was done. Don't know why exactly.
stlrj 05-15-2014 12:42 PM
Both my 87 Carrera coupe and 82 Targa are stock showroom height and they both feel like they have power steering. At least that's what my neighbor tells me whenever he compares my 911s to his lowered 911s. Something to think about...
http://forums.pelicanparts.com/uploa...1399390661.jpg
http://forums.pelicanparts.com/uploa...1399391216.jpg
Cheers,
Joe
Redwood PCA since 1976
Josh D 05-15-2014 01:10 PM
On my car, as the front tires wear, the steering gets heavier. I didn't realize how much until I put new tires on.
nickyclyde 05-15-2014 01:15 PM
^ what Josh said. Big difference in the effort required with tires with more than 50% wear. Also big difference as tire pressure is reduced
Bill Douglas 05-15-2014 01:58 PM
Oil the universal joint in the steering shaft. I did mine a month ago and it made a huge difference. Mine is a right hand drive so it may be a little different - mine is located in the smugglers box.
