jk911's Avatar
fuel lines
1975 911 2.7 .
Does anyone know what size fuel lines run off and to the fuel tank.
What about throught the tunnel. Are these lines metal or are they the hard black plastic. I took off the cover where the gear lever connector is at the back in the middle of the back seats and I noted 1 hard plastic fuel line.
Any ideas ?
Old 09-18-2002, 10:21 PM
Slumlord
Porsche_monkey's Avatar
The large (supply) line is 1/2" ID and the small return line is 5/16" ID, as far as I remember.
I removed my hard plastic lines that run inside the car and installed bent steel fuel lines on the bottom of the car, but I am rethinking that decision. One bump to the bottom of my car could sever the line.
Old 09-19-2002, 04:47 AM
Senior Member
Hello
Your PVC-Teclamit fuelines should be fine ( They don´t like UV light and acids ).
The rubberlines are renewable. You need 8 and 6mm.
Grüsse
Old 09-19-2002, 06:02 PM
