What type of paint?
Does anyone have a recommendation for a spray paint for the black engine deck lid grill?
Mine is looking pretty weathered and I was wondering what type of paint sticks well to it.
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 06-13-2014, 09:57 AM
Cooper911SC's Avatar
A product like SEM Color Coat in Satin Black will work well.
The number 1 & 2 & 3... Thing is remove the grill and PREP. it very well. Clean all of the nooks and crannies first with a degreaser like Simple Green and a tooth brush.
Follow this with a light scotch brite pad. Rinse and let it air dry.
Next use a wax and grease remover like SEM Solve.
Finally, I would reccomend using an adhesion promoter like Bulldog.
If you just do a "quickie" clean and spray paint you will be sad later when it peels. Big mess and hassle to have to completely strip and start over.
That grill sees a lot of engine heat cycles plus getting blasted by UV from the sun anytime it's outside.
Happy refinishing.
Cooper
Old 06-13-2014, 10:15 AM
47silver's Avatar
Careful with the solvents especially the degreaser as it is absorbed through the skin use good gloves long sleeves safety googles and and good solvent mask.
Old 06-13-2014, 03:07 PM
Best way is hard to find and expensive.
Clean with acetone. Paint with satin black 7777 Rustolium spray paint. Great stuff.
Home Depot has it for$4.00 or less. It is very very good! By resto friends love it.
Tell everyone it is SEM.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-13-2014, 05:47 PM
I have had better luck with products like "Back to Black"... never peels, etc.
Paint on the plastic almost always peels.
Remove the grill and treat it.
Old 06-13-2014, 05:48 PM
Back to Black is a plastic cleaner, isn't it? Does it also dye the plastic to help cover up the whitish, faded areas?
Old 06-13-2014, 06:03 PM
Yes, it takes the grille back to black... gets rid of the gray/white stuff. You may have to re-apply after a couple years but no peeling.
Old 06-13-2014, 09:05 PM
IROC's Avatar
I painted mine with Wurth Satin Black 17 years ago and it still looks fine.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-14-2014, 04:29 AM
was it Rustoleum 7777?
03 Boxster
Old 06-14-2014, 06:44 AM
IROC's Avatar
It was Wurth Satin Black.
Mike
1976 Euro 911
Old 06-14-2014, 10:37 AM
Nate2046's Avatar
Recently stripped all the flaking paint off my grill and tried the 'Back to Black.'
Turned out exactly as I had hoped, nice, uniform, deep black and like you said will just have to retreat when the time comes.
Old 06-14-2014, 12:36 PM
