Slumlord
Sunroof Liner
I know I'm an idiot, but now what?
I am (slowly) restoring my 74 911. I took my sunroof out 6 months ago and stored it on top of the spare tire. Being ready to reassemble the interior I find the rubber from the tire has nicely bled through into the liner and I have the name Pirrelli (in reverse) with a nice outline of the tire diameter. The mark actually bled through the liner and is visible front and back. I have scrubbed and tried every solvent, no luck removing the 'stain'. Now, not wanting to replace the entire headliner, which I have just tightened and glued in place, what can I do? A new cover will not match the rest of the liner, so that is not a preferred option. Does anyone have a slightly yellowed (previously white) sunroof cover for sale? Any other suggestions?
Information Junky
There are "vinyl-paints." Color matching could be tough, though.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
You might try calling around to upholstery shops in your area to see if they will give you scraps removed from a car on which they worked. Since the sunroof isn't that large, a good size piece of scrap should do the trick and you stand a good chance of matching the color somewhat.
--- Will Ballance '82 911SC coupe |
