SCWDP
Accelerator Cable, Slack Adjustment or Broken Part?
![]() Hopefully someone can help with this fix. I've got slack in the cable at the point where it goes through the bracket. It's about 1/2 inch, and it keeps me from getting full throttle. Much Appreciated! SC |
That appears to be the cruise control cable.
The throttle linkage is NOT cable type. I would suggest adjusting the throttle linkage to get full throttle. A helper can verify as you push down the accelerator pedal. You shouldn't have the cruise set when in full throttle mode anyway.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
SCWDP
I was wondering what happened to the cruise control? Awesome, and thanks!
The 6sided nut you see at the mount is the adjustment to take the slack out. Of line to throttle.
Bruce |
