Remove Rocker Panel Rubber
I'm about to pull the trigger on an nice SC. I can't wait to have it. Once I get the car the only thing I'd like to do is remove the rocker panel rubber. I know it slides on and off, but from what I've seen there is some sort of lip that keeps it on.
What all is involved in taking the rubber off and making it look like it was never there (see the picture below)? Any help would be great!
Old 05-25-2014, 01:43 PM
It's pretty easy. Just remove the 2 end caps at each wheel well, fore and aft. There will be 2 screws that hold them. Remove the the rocker panel trim. You can just pull it out. Remove the 3 screws on each side that hold the rocker panel to the body. On the passenger side there is also 3 screws that also hold the oil line clamps that are also attached to the bottom of the rocker. So, might be a good idea to put a block of wood or two to support the oil lines. You could fill the screw holes.
John
"Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage
Old 05-25-2014, 01:50 PM
Thanks John.
My main concern is with the grooves that keep the rubber on (see picture below). Does it require body work, painting, etc to get the refined look like on the picture from my first post.
Old 05-25-2014, 03:00 PM
non-whiner
mreid's Avatar
Once you remove the rubber strip, you expose the screws that hold the rocker to the body. You can then remove the rocker for the look in the picture you posted. You should fill the holes. Here's mine:
"Too much is just enough."
Old 05-25-2014, 03:05 PM
Thanks mreid.
So from what John said, I understand there are 6 exposed screws on each side where I would need to fill the holes. Is that correct?
What did you use to fill the holes? Also, I'm guessing the job required some paint as well?
Old 05-25-2014, 03:27 PM
You would fill the holes with body filler sand and then paint to match. Same as how you would fix any damage to a steel panel.
Rutager West
Old 05-25-2014, 04:13 PM
What you're seeing in that pic is the absence of rocker panels. The panels have been removed.
John
Old 05-25-2014, 06:42 PM
Once a friend of Cliff
juanbenae's Avatar
I filled the holes in the body with rivets. small little head over a drop of por15. not concourse, but should magnus have done it, berries!!
Old 05-25-2014, 10:02 PM
