gduke2010
gduke2010's Avatar
Brake pedal
It seems that either my brake pedal is getting harder to push or my leg weaker. I'm wondering if I upgrade my master cylinder and booster would help? It's especially, hard to blip the throttle going into a corner and seemed easier a few years ago.
Old 10-09-2017, 07:08 PM
Grappler
Rodsrsr's Avatar
Do some resistance training.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 10-09-2017, 07:10 PM
Diss Member
Quicksilver's Avatar
The "upgrade" for the master cylinder is a larger cylinder that increases pedal effort.
Either you have a vacuum leak, a failing booster, a failing master that is binding, an issue with the pedal, or a perception issue.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-10-2017, 10:25 AM
I had this issue and it was just the brake pedal binding up from age. Rebuilt pedal box with new bushings solved it. So check that before you dump $$ on new master cylinder or booster or both.
Old 10-10-2017, 06:52 PM
gduke2010
gduke2010's Avatar
Thanks going to check it out this weekend
Old 10-10-2017, 08:29 PM
gduke2010
gduke2010's Avatar
Went for a drive today and no problem with the brake pedal. i had difficulty blipping the throttle at first. Then realized my knee was wedged under the steering wheel. when I vacuumed the car this summer, I moved the seat forward and didn't move it all the way back. So, I moved the seat back to where it felt comfortable once again and the heal-toe felt comfortable.
Old 10-14-2017, 04:13 PM
