911 Targa Roll Hoop
I have a 1974 targa thaT has the roll hoop painted black. I want to take it back to the classic brushed aluminium look. I'm told that it is actually steel underneath and that it needs to be sealed, but that you can't do this with clear. Does anyone have advice how I can get that brushed aluminium look?
Many thanks
Ketchp
Old 05-29-2014, 08:16 PM
The bar is stainless steel not aluminum. I'd think you only need to strip it and polish or buff to the finish you want. Mines an 87 and painted black as all were from about 74. Striped down on early ones with chrome or polished aluminum trim to match looks great.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 05-29-2014, 08:29 PM
so being stainless steel do you think I can just leave it as bare metal. The shop guys are telling me that it needs to be sealed with something which seems odd??
Thank you
Old 05-29-2014, 10:04 PM
porwolf's Avatar
Thank you
Here are a couple of links. Hope it helps.
Black Targa bar to Silver...
Refinishing Targa Bar Cover...HELP !
I understand The Targa bar stainless steel does not need "sealing". But, I guess, it depends on the stainless steel grade. Maybe it is discussed in the links.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-29-2014, 11:01 PM
I did this last spring. Its an easy job to do in an afternoon or two. I could have saved a lot of time by choosing the correct abrasive the first time. I ended up too much shine before I figured out how to give it that brushed look. Finally got a hold of some synthetic steel wool and used long straight strokes and now it has a great looking brushed finish.
Lots of pics of my own here:
Targa bar paint or strip for chrome look
Parts you will need for a nice refreshed Targa bar:
Part numbers:
901-565-930-41-M260 Targa Bar to Rear Window Beading, 911 (1974-89)
911-565-091-45-M260 Targa Front Bar Seal, 911 (1974-85)
999-591-423-03-M260 Speed Nut for Hood & Deck lid Emblems (6)
999-703-186-40-M100 Plastic Rivet/Plug (sold per each, 4 required), 911SC / Turbo (1978-1983)
901-565-361-40-OEM Targa Aligning Seal (sold per each, 2 required), 911 (1974-85)
901-801-153-40-OEM Plastic Screw Plug, sold each (4 required), 911SC / Turbo (1978-1983) (TARGA)
999-591-384-40-OEM Cap for Plastic Rivet/Plug (sold per each, 4 required), 911SC / Turbo (1978-1983)
1982 911 Targa, 3.0L ROW with Webers
Old 05-30-2014, 10:42 AM
That looks fantastic, thank you so much for your help. I'll post a picture when it's done
Old 05-31-2014, 02:50 PM
