Team California
speeder's Avatar
defective SC valve springs?
I was talking to Walt at Competition Engineering today, (probably the most respected Porsche machine shop in the U.S.), about sending in my heads when I do top-end on SC next month. When I told him that it was an '82, he advised me to replace the valve springs due to a batch of bad ones in '82 that tend to break. I believe him, but was surprised that I have never heard of this one on this board or elsewhere. Anyone else familiar w/ this? John Walker? Dave B.?
Just wondering.....
Denis
Old 09-18-2002, 06:59 PM
good idea. lots of SCs had/have broken springs. they're cheap.
206 637 4071
Old 09-18-2002, 07:20 PM
Send a message via AIM to 82SC
yeah when I bought my 82SC...had a couple broken springs
MJ
Old 09-18-2002, 07:24 PM
Team California
speeder's Avatar
Thanks, John. I'm gonna go ahead and do it, when someone like him, (or you), talks I listen. I'm also installing 964 cams+SSIs, want it to be nice and tight.
Denis
Old 09-18-2002, 07:27 PM
Author of "101 Projects"
Wayne 962's Avatar
If Walt says so, then it must be true.
Walt told me a month or two ago that the newer springs are very good, and hardly ever come up bad...
I recommend replacing valve springs no matter what - why risk it?
-Wayne
Old 09-18-2002, 08:29 PM
Team California
speeder's Avatar
Always on the learning curve..... I was not aware that these wear out/ break. They will be replaced.
Denis
Old 09-18-2002, 10:32 PM
MBAtarga's Avatar
Just another data point on this. When shopping for my first Porsche purchase early last year, I found an 83SC I was seriously considering. The owner, of 13 yrs, said the only "engine" work to date (130k miles) was when it was in the shop for a previous valve adjustment, the mechanic found a broken valve spring. Perhaps the problem is not just limited to 82's.
I opted against this car, for other reasons, and soon found the 83SC I currently own.
Mark
'83 SC Targa - since 5/5/2001
Old 09-19-2002, 05:54 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Valve springs are one of the most stressed parts of an engine....they work millions of cycles under very harsh conditions.
When the spring is new..it follows the curve of the cam with no problem....but when they get old....term in racing is "the engine has gone soft" ...then they must be changed.
In formula Ford....when the engine goes "soft" you can hear the difference right away.
The car loses several hundred RPM (can't rev as high) and the overall sound is just not as "crisp".
As John says...they are cheap...replace them.
Bob
Bob Hutson
Old 09-19-2002, 07:49 AM
tops911's Avatar
on my 78 SC it has had 5 intake valve springs changed due to breakage. I have the service records and most were changed early in its life. It does seem odd that only the intakes have been the ones to break.
Old 09-19-2002, 07:58 AM
Senior Member
Jdub's Avatar
Without visual inspection, and without attemtping to rev the engine to see if I have lost revs at the top, how can I determine if a spring is bad? I guess I am asking if there is an audible or ? way to confirm this.
Thanks,
John
'78 Targa in Minerva Blue
Old 09-19-2002, 08:05 AM
hmm...well I have the rocker covers off at this point and the rocker arms...sould I do a spring change too?
I know my car has not gotten work since it was built...
and I will repeat the previous post...what is a good way to check besides a spring compressor?
how much should a full set of springs run?
MJ
Old 09-19-2002, 09:03 AM
Team California
speeder's Avatar
From what I've heard, a good flashlight and someone who knows what they're looking at is all it takes to find a broken valve spring(or 3).
Denis
Old 09-19-2002, 01:52 PM
I'd replace them, too, cheap insurance.
I remember in Anderson's book, he talked about a bad batch in the early '78 model run.
Old 09-19-2002, 01:53 PM
there's an outer and an inner spring. the outer generally breaks. the inner is pretty weak, and can be compressed pretty easily with your thumb. so when the rocker is in the position where you would adjust the valve, see if you can push in on the rocker, against the spring and actually depress the spring a bit, like 8-10 mm. if you can move it with your fingers, it's broken. baum tools, and maybe pelican too, sells tools to replace the springs without removing the heads. if you're real flexible and patient, you can do it with the engine in the car. some are a lot easier to get at than others. obviously, the rocker and shaft need to be removed first.
206 637 4071
Old 09-19-2002, 06:51 PM
