-   -   considering buying another porsche, but it has no number on the engine case (http://forums.pelicanparts.com/porsche-911-technical-forum/813506-considering-buying-another-porsche-but-has-no-number-engine-case.html)
gostraight 05-28-2014 07:36 PM
should I even consider it? I've been told that factory replacement cases came with no number stamped on them. Can anyone confirm this?
James Brown 05-28-2014 07:46 PM
yup true, unless someone ground off the numbers.
tctnd 05-28-2014 07:46 PM
If you can confirm that it has never been stamped then a replacement case seems likely. If there is even a hint that an original number has been removed, don't touch it.
just my 2 cents..
Phil
gostraight 05-28-2014 10:24 PM
Thanks for the replies guys. I feel a lot better about this deal now.I took a metal worker over to get his opinion on the matter and in his professional opinion no one tampered with the cast. There are no scratches of any sort and the surface is completely square and similar in finish to the rest of the casting. I tend to agree, but I welcome your opinions. I took a couple of shots of the area so please feel free to comment.... thankshttp://forums.pelicanparts.com/uploa...1401340981.jpghttp://forums.pelicanparts.com/uploa...1401341031.jpg
gostraight 05-28-2014 10:39 PM
better picshttp://forums.pelicanparts.com/uploa...1401341886.jpg
http://forums.pelicanparts.com/uploa...1401341978.jpg
timmy2 05-28-2014 10:50 PM
Looks like it may be a factory replacement case mainly as there doesn't appear to be a stamp on the flat by the oil sender like 930/06 or anything similar indicating a type and year/model.
slodave 05-28-2014 10:51 PM
Agreed.
gostraight 05-28-2014 10:56 PM
awesome.... looks like this deal will go through.....Thanks again for all your help!
911SauCy 05-29-2014 05:35 AM
I would not make the deal happen unless there were receipts or a paper trail of some kind proving this is a factory replacement case.
Just my $.02
