DYI rebuild a smog pump?
Is it possible to DYI rebuild an air (smog) pump?
I have a 1980 Euro SC with a bad pump that I would like to get working for the yearly emmissions test. Any one ever taken one apart and repaired it? Thanks BernieP |
I had a friend take one apart and replace the bearings (the bearings were replaced by a local guy who rebuilds alternators). Upon reassembly the pump would lockup and not turn properly. I took on the challenge of finding what was wrong. It turned out there was a very subtle reassembly error; it was possible to get a part in backwards (I seem to recall it had to do with a vane). When you take the pump apart, carefully note, record and mark the orientation of every part and put it back together the same way so you don't have to spend two hours figuring out why it won't turn when you put it back together. Jim
Bernie-
Did removing the smog pump make much of a difference in performance? I was thinking about doing this to my car (1983), but did not know if it was worthwhile. What do you think? Adam |
Thanks for the info -
How about a cat bypass - is it a worthwhile ben franklin and knuckle busting? (No, I'm not _trying_ to mess with the air around my car, it just seems that I see a lot of posts with people making these modifications). Adam |
