-   -   Looked into head for the first time on a new purchase. (http://forums.pelicanparts.com/porsche-911-technical-forum/813867-looked-into-head-first-time-new-purchase.html)
spb350 05-31-2014 02:51 PM
Just pulled my CIS and I'm cleaning things up before the new air box goes in. I just looked into the head for the first time today, looks pretty good? Anybody see any problems looking in, or around the port ?
Thankshttp://forums.pelicanparts.com/uploa...1401572923.jpg
http://forums.pelicanparts.com/uploa...1401573038.jpg
http://forums.pelicanparts.com/uploa...1401573054.jpg
Jerome74911S 05-31-2014 03:11 PM
I don't think you could ask for anything nicer than those ports. If mine are that clean I'll faint.
CountD 05-31-2014 03:51 PM
What year is it? Looks like my '75. Could you tell me how long it took you to get the whole thing on, and maybe which way worked best? I need to do mine next week.
I can't pull the motor or even drop it a bit because of the cars location and lack of space.
Nice ports though. That CIS really cleans the back of the intakes...
spb350 05-31-2014 04:07 PM
The motor is a 75 and its in a 76, I think the original motor came apart and the PO put this long block in.
I haven't put mine back in yet, I'm waiting for my new (used) air box to arrive. The one I have blew apart and the PO glued it back together, it was a poor job. I don't think it will take very long to put it all back in, probably an hour or two. It was only about three hours to get it out and I took my time, marked all the lines and took lots of pics.http://forums.pelicanparts.com/uploa...1401577623.jpg
http://forums.pelicanparts.com/uploa...1401577639.jpg
Jerome74911S 05-31-2014 04:11 PM
That would have been perfect if he had used more glue. . . That said, it probably works with no leaks whatever.
Is the replacement (used) plastic, too? I'm looking at a welded stainless steel example.
spb350 05-31-2014 08:05 PM
Yes I bought an 81 - 83 used box, they have an upgraded distribution method for the cold start valve that is supposed to prevent the backfire.
ZAMIRZ 05-31-2014 08:47 PM
Good on you for getting that off your car and putting on a nice, non-damaged piece. You can protect your investment by installing a pop-off valve to avoid blowing out another one.
