3,2 Carrera misfire between 2400 and 2800rpm
Hello,
a friend told me about a problem with his 3,2 and ask if I can help him. When accelerating, but only at full throttle, the car engine hesitate and "shoots" misfires into the exhaust. At higher revs the engine runs strong, and when not full throttle everything runs fine...
Any ideas?
thanks everyone, regards
Malte
Old 05-29-2014, 12:10 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Flywheel rpm sensor, make sure the gap is set correctly.
Old 05-29-2014, 12:39 PM
997Sbeebe's Avatar
i couldn't hear a thing due to ZOA's avatar. :-O
'04 GT3
'97 C4S
'90 C2
'86 951
Old 05-29-2014, 03:02 PM
Mr9146's Avatar
Tighten the grounds on the manifold.
Old 05-29-2014, 11:58 PM
Lufeco's Avatar
Bad spark plug wires.
Old 05-30-2014, 02:06 PM
Brew Master
cabmandone's Avatar
I'd be interested in knowing what you find. My 85 pops a little when I'm in the throttle. I'm going to change the cap and rotor and thinking about new wires too since I really don't know how old my wires are. I've read too that they will sometimes pop if you have a catalytic converter delete pipe. Don't know if that's true or not but mine has it and it pops.
Old 05-30-2014, 04:56 PM
Thank you for the answers!
Spark wires,cab,... are new. At the moment where it pops the ignition retards by I think 90 degrees (difficult to catch it)
Any ideas?
Old 05-31-2014, 11:10 AM
Follow this thread also. 3.2 Carrera Race Car Miss. Need help.
Rick
88 Cab
Old 05-31-2014, 11:33 AM
Thanks Rick, I think it is a different problem as ours is always present no matter if cold or hot, it is from the first minute as long as you hit full thorottle. -and always around 2500 rpm only. What could make the DME change or retard the iginition?
Old 06-01-2014, 11:39 AM
vince_wa
I had a similar problem on my 87 3.2 and it turned out to be manifold leaks. Significant hesitation from about 3000-4000rpm. Did not find problem until I used a smoke machine to find leaks.
Garage - 1987 911 widebody
Old 06-01-2014, 11:57 AM
Hi Vince,
thank you for your answer. I tried with brake cleener and no changes...
It drives my mad!
Old 06-02-2014, 05:02 AM
sp_cs's Avatar
Sounds like a symptom of a failed/failing cylinder head temp sensor (chts)?
Old 06-02-2014, 09:00 AM
