keitho64's Avatar
Need Flywheel specifications for 215MM thickness to give machine shop
I am having the flywheel on my 1969 911T cut / refinished. The machine shop is asking for the specifications on the flywheel so they can assess if it can be cut. Does anyone have the specifications for a 215MM flywheel which I can share with the shop? I am assuming they want to know the minimum thickness it can be cut to.
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 04-16-2007, 08:17 AM
