-   -   Turn signals don't work (http://forums.pelicanparts.com/porsche-911-technical-forum/813933-turn-signals-dont-work.html)
hemmah 05-31-2014 09:45 PM
I have a 1969 911T and my turn signals don't work. My emergency flashers work. All other lights work. The high beam switch works.
Is the solenoid (or other delay time switch) for the turn signal the same solenoid for the emergency flashers?
What do you think is the problem with the turn signals?
Porboynz 05-31-2014 10:09 PM
Check fuses and turn signal relay, its located behind the fuel/oil level gauges. Start by reseating it, then replace it. (or you can pry it open and investigate) Its a rectangular black plastic relay. Search on "Relay Identification on a 69T"
bavaria911 06-01-2014 07:54 PM
My 1970 did the same thing three years ago. I just opened the hood and removed every fuze cleaned the ends and the fuze box ends, sure enough the turn signals worked and ever since.
hemmah 06-02-2014 09:29 AM
Thanks All. I have some contact cleaning to do. Now I know what relays are what function.
