-   -   Bizarre twin plug set up ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/813975-bizarre-twin-plug-set-up.html)
dzlndan 06-01-2014 05:51 AM
Purchased an 1982 targa without any background info. Can anyone help me identify this bizarre twin plug set up? It has twin MSD. Car runs good now but the (rear?) Distributor will need a new belt soon and I have no clue where to ascertain one of those puppies.
http://forums.pelicanparts.com/uploa...1401630663.jpg
http://forums.pelicanparts.com/uploa...1401630681.jpg
dipso 06-01-2014 06:23 AM
Could it just be a single plug with an extra msd in case of failure? I only see one coil. And that black thing in the first picture only has 4 terminals, not 6.
Does it actually have 12 plugs?
jpnovak 06-01-2014 06:25 AM
There was a thread years ago about cam driven twin plug setups. Search for Grady Clay's response on the subject.
In a way its a "hidden" twin plug setup.
dzlndan 06-01-2014 06:33 AM
No twin set up, 12 plugs second cool is hidden to the left of engine mounted near the fuse panel, just the way the photo is it looks like possible 4 but it def has six plug wires on the back dist cap. I will try to get better photos and maybe even from under side to see the belt drive off the cam.
dzlndan 06-01-2014 02:47 PM
http://forums.pelicanparts.com/uploa...1401662831.jpg
This pic shows the second coil
bh912e 06-01-2014 05:21 PM
Wow, cool setup!
pors1968 06-02-2014 02:15 AM
It set like old airplane engine .Double ingition .
bavaria911 06-02-2014 03:14 AM
I don't see it. Where is the 2nd coil?
Elombard 06-02-2014 03:17 AM
Its up on the side on the right - black, kinda stealthy.
I have heard of these set ups but I cant remember where I read about them. I wonder if the belt that drives the 2nd dizzy will even be available? Maybe its just an MFI belt?
sand_man 06-02-2014 05:22 AM
Posting this for a visual. A 962 engine (not mine) with that setup. It uses the "regular" dizzy in the typical spot to fire six plugs and then an additional dizzy off of one of the cams to fire the other six.
http://forums.pelicanparts.com/uploa...1401715663.jpg
http://forums.pelicanparts.com/uploa...1401715323.jpg
dzlndan 06-02-2014 04:31 PM
Some more photos
From the under side
http://forums.pelicanparts.com/uploa...1401755443.jpg
From the top side in the back
http://forums.pelicanparts.com/uploa...1401755476.jpg
dzlndan 06-02-2014 04:34 PM
Two more from the top side
http://forums.pelicanparts.com/uploa...1401755645.jpg
http://forums.pelicanparts.com/uploa...1401755655.jpg
Flieger 06-02-2014 05:06 PM
MFI belts are wider than that. You might be able to find something from Gates on McMaster-Carr or SDP/SI that would fit as a replacement. Have fun changing it though.
Elombard 06-02-2014 06:06 PM
Yeah it looks like they clearanced the shock mount cross bar with a BFH. Looks like something I would do. I think I can see some numbers on the belt i n one of the pics, maybe if you can get it off you could source it. I would be scared to lose the timing if I took it off with the motor installed.
euro911sc 06-03-2014 09:17 AM
You could remove the cap on the rear dist. and observe the orientation of the rotor when you set the engine to TDC. Then mark it. When you put the belt back you should be able to hit that mark. Should be obvious if you are +-1 tooth on the belt.
My concern would be the changes in timing over time as the belt wears and stretches out. How do you tension it? what tension do you set it at if its adjustable?
Note there is no belt on the 962...
Interesting setup...
jpnovak 06-03-2014 09:23 AM
I have tried and tried to find the previous post on the subject. I can't seem to find it but I know its there.
sand_man 06-03-2014 09:55 AM
Not to hijack in any way as I realize the OP's second dizzy is being driven by a belt via cam, but I thought I would share these pics. Several years ago, Neil Harvey of Performance Developments (a premier 956 and 962 engine builder) was handling all of the machine work on my 930 engine. I decided to go twin plug. This was one of the options he mentioned. Obviously borrowed from his years with the 962 engine:
http://forums.pelicanparts.com/uploa...1401818030.jpg
http://forums.pelicanparts.com/uploa...1401818046.jpg
http://forums.pelicanparts.com/uploa...1401818066.jpg
http://forums.pelicanparts.com/uploa...1401818088.jpg
http://forums.pelicanparts.com/uploa...1401818104.jpg
sand_man 06-03-2014 09:57 AM
^^^this dizzy would have been attached to the turbo oil scavenge pump, which runs off of the driver's side cam.
safe 06-03-2014 12:53 PM
Really cool!
dzlndan 06-03-2014 03:37 PM
Yes exactly where my belt is connected
dzlndan 06-03-2014 03:40 PM
MSD says they only make belt drive systems for V8 engines
I figured since it has 2 MSD units on it, that maybe MSD made a belt driven distributor in the past. But the tech I spoke to one the phone today said they only make them for V8 engines. Looks like front mounts for GM small and big block motors.
dzlndan 06-03-2014 03:42 PM
Thanks for your hard work looking! I did the same.
dzlndan 06-03-2014 03:43 PM
Not a hi jack at all, love the input! Thanks
sand_man 06-03-2014 05:34 PM
Just thinking it wouldn't be impossible to re-work the second dizzy you have, such that you could eliminate the belt and adapt it directly to the cam.
safe 06-03-2014 09:44 PM
Did a quick google on timing belts and found a few places that sells belts and pulleys, for example: Robot MarketPlace - Timing Belts
safe 06-03-2014 09:47 PM
If it has a twin plug set up, what kind of other goodies does this engine have? :)
