Oil filter gasket doesn't get full seal
I have a reproduction 914-6 oil tank for my 3.0L SC motor. The filter housing screw was not center when drilled. On one side I get about 70% of the gasket sealed - do you guys think this is good enough or will it leak - how much pressure it is under? Using a Mahle OC54 filter. Is there a filter with a wider gasket?
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 06-02-2014, 06:41 PM
emac's Avatar
You will blow a ton of oil out. I would get it right before running her
Old 06-02-2014, 08:17 PM
Reiver
Reiver's Avatar
What's cold psi for 20/50 again? I'd get a different tank. Not worth the mess or oil starvation.
Old 06-02-2014, 08:27 PM
