-   -   ack - tach signal noise? (no tachometer / no speedo) (http://forums.pelicanparts.com/porsche-911-technical-forum/814283-ack-tach-signal-noise-no-tachometer-no-speedo.html)
island911 06-02-2014 07:26 PM
I just don't get it. The tach moves up only when jumpered to a sqr wave signal generator. (and does so with less voltage than otherwise present - same for speedo)
The voltage of the car seems good (13.8 - 14.1 running).
Swapped in a spare CD - nothing
Getting 4.xx volts at the signal (black and purple) wire. ...jumpered directly to the CD signal plug just to test. - still nothing.
Grounds jumpered...
All I can figure, at this point, is that there is maybe some extraneous electrical noise pulsing thru the system.
Any ideas out there? Do voltage reg's get noisy?
