-   -   VIN build date (http://forums.pelicanparts.com/porsche-911-technical-forum/814290-vin-build-date.html)
JJ 911SC 11-10-2014 01:17 AM
Originally Posted by donlan (Post 8346345)
Hello, To add a bit more confusion [for me] . I have been given some information on this forum prior. Mine has 9113101905 and on the left hand door frame [below engine pull handle] on sticker it has perforated numbers 2/73 and 9113101905. Had an 0 438 140 001 W U R. Fuel pump mounted above left hand rear suspension. Etc.... I purchased car in U.S.A. in June 1994. Regards Michael.
911T US CIS, 911/91 Engine (6133001-6136092) - 1944 build.
They switch from mechanical to CIS fuel injection in Jan 73
donlan 11-13-2014 12:35 AM
Hello,I was looking up some fuel pressure specs. in the little Tech.specs.book and I noticed that the C.I.S. cars started at chassis no.911 310 1501...and my eng.no.is nothing like the ones you quote.Michael. [I'm trying to get it to run after an 18 year rest]
JJ 911SC 11-13-2014 01:11 AM
Maybe it got an engine swap at some point.
What is you engine type and serial #?
donlan 11-13-2014 01:20 AM
911/51*6124238*.Michael.
JJ 911SC 11-13-2014 01:56 AM
Fitted to 911T US
84mm bore x70.4 mm stroke
2.4 Liter
Mechanical Fuel Injection
7.5:1 Compression
140HP @ 5600 rpm
148 fp @ 4000 rpm
Not a direct fit to your chassis number but your car was completed in Feb 73 so it could be a Porsche thing :D:):D A later chassis with earlier engine.
donlan 11-13-2014 02:26 AM
I've heard that from a few people now. It has C.I.S with steel inlet tubes,swirl pot tank,001 WUR,metal roller fuel pump above l/h rear suspension etc...it has a clear sticker with black writing on the l/h side window[behind driver] DR Porsche.....911....Co2...emissions....etc. and apart from some factory/dealer options is standard.Michael.
djpateman 11-13-2014 07:20 AM
As JJ says, but it is a 1972 engine, so definitely not the original.
kchin 11-13-2014 01:12 PM
I am new to forum. Did post a question earlier regarding the spec for a 911(WPOCB2967MS461717) 1991/964 I believe. The engine serial is 62MO8867, I am
pretty sure this is not the original engine, can anyone shed some light on this engine.
Thx
Ken
JJ 911SC 11-13-2014 02:53 PM
Thx
Ken
Ken,
The engine type M64/01(62M00001-on) was fitted to a numbers of the 911 cars in 1991.
It does not list WPOCB2967. Its usually a letter in that position.
Are you sure it a "7"? Then again it could be a "check sum" number which would not matter.
The M in the VIN 10th position is definitely for a 1991 model.
MS460001-2207 would be US Cabrio chassis.
kchin 11-13-2014 03:51 PM
Originally Posted by JJ 911SC (Post 8352114)
Ken,
thx much. the VIN# definitely indicates a 1991 cabriolet but I am not sure about the engine.
JJ 911SC 11-13-2014 04:09 PM
If your car is a Cab, that engine fall in that type/serial fitted.
Why do you think it is not?
You could spend $125 and get a COA that would confirm the match but with Porsch book keeping its always a hit and miss.
Tbone1209 05-22-2017 10:50 AM
Hey guys- Update on calling Porsche and verbally getting any info from them. It's apparently not happening anymore. Have to order a COA to get anything.
I have an 84 M491 Turbo look with a built 3.8 so all that was important to me was a build date. They weren't willing to even entertain a conversation about it.
In the off-chance someone might have info on the car, the VIN is WP0AB0917ES122277
T
JJ 911SC 05-22-2017 11:58 AM
(misleading info removed)...
You have serial 2277 out of 2282, so one of the last one.
If your "3.8" references is 3rd of August 1984, that was a Friday so IIRCC it was part of the E program as they would switch to the F program on Monday the 6th of August 1984.
Hcarraro 05-22-2017 07:22 PM
I have found this site to be very helpful. Click on https://www.stuttcars.com/technical/vin-decoder/
Good luck
Henry
Tbone1209 05-22-2017 11:08 PM
Thanks. Great information.
My 3.8 reference was referring to a 3.8L. As in 993 motor swap. When do you think the later Turbo looks would have been made?
JJ 911SC 05-24-2017 01:59 AM
Originally Posted by JJ 911SC (Post 9597187)
The 9th character should be a letter...
oops... Short memory! Actually, the 9th character is a Checksum Digit that can be 0 to 9 plus X and Z.
Have fun calculating it: https://en.wikibooks.org/wiki/Vehicle_Identification_Numbers_(VIN_codes)/Check_digit
