I’ve narrowed down my overheating problem in my 85 Euro 930 to timing.
I checked my timing today after the car was running hot. This is what my timing light read: 1000 RPM 7 degrees BTDC 2000 RPM 0 degrees BTDC 3000 RPM 6 degrees BTDC 4000 RPM 5 degrees BTDC Is this even possible? Isn’t timing supposed to increase with RPM’s? Apparently I have a very serious problem at hand. Is this an issue with the distributor-timing curve? Any help would be greatly appreciated.
This is why your engine is heating up. You need to check out your advancement mechanism or you could burn a hole in the top of your pistons.
Steve Last edited by stormcrow; 09-28-2002 at 04:36 PM.. |
I would remove the distributer cap an check to see if the mechanical advance is frozen, you should be able to move the rotor 10-15 degrees with relative ease, if it can be rotated or is very hard to rotate then it is stuck.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
Senior Member
How about putting the unit in a distributor machine and checking it out at the various RPM's? Sure makes it a lot easier to do then you can stick it back in the motor and be positive of the advance curve.
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Thanks for the information everybody.
This is a used twin-plug distributor that I picked up a while back but I never had it fully tested. I will pull the cap to see if I can manually advance the rotor. If it's stuck, how easily can it be repaired? Would a dealer have a distributor machine to check for proper advance? If it isn't stuck, what else could be wrong?
Senior Member
Usually the older shops have the distributor machines. Most dealers are parts changers and would not have one. Call around to the older performance shops and see if you can find one.
Joe
I pulled off the distributor cap today and checked to see if I could manually advance the rotor. I was able to rotate it counter-clockwise roughly a quarter inch. When I let go of the rotor it would spring back into place. Does this indicate my mechanical advance is working correctly? The rotor will not move clockwise.
I decided to test my retard and advance vacuum canister ports with a mity-vac. What I discovered is that my advance port works when I apply vacuum. I can visually watch the internal parts rotate (sorry, can’t be more specific). When I apply vacuum to the retard port, it does nothing. Nothing moves, it just holds vacuum. Would this cause the engine to overheat? |
Try putting pressure in the dist. pot. See if the mechanisum moves with pressure. Do you have the factory timing spec.? If so follow the manual for setting the timing. The factory manual tells you how to check the dist.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Blown,
It was set to 25 degrees at 4000RPM. This was after the engine was warm with both vac lines plugged. |
Is that the spec.? I thought it was 29 degs. at 4000. Do you have the manual? You can check out the workings of the dist. on the car without a dist. mach. if you read the manual.
I think you total timing is retarded a little
>Is that the spec.? I thought it was 29 degs. at 4000. Do you >have the manual?
The 25 degree at 4000RPM spec. was recommended by a few turbo experts due to my engine modifications. >You can check out the workings of the dist. on the car without a >dist. mach. if you read >the manual. Can you elaborate on this? Is the retard pot supposed to operate on pressure or vacuum? Thanks |
Author of "101 Projects"
Okay, confusion lies here. Do you have a twin plug setup, or not? You said you did, but the photo shows a single plug system.
Total advance should be reduced with a twin-plug setup... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Sorry Wayne... the photo was for illustration purposes only.
This is a picture of my distributor: |
I don't know about your year but to check out the dist. You need the manual and a timing light and a vacume gauge. Follow the procedure in the factory manual.
The pot on my 75 930 has only one port and it is a vacume retard. I read that some 930 retard on boost as well as vacume. I don't think timing is the cause of your overheating problem. Have you checked your mixture?
CO was set to 3.5%, so I don't believe it’s a mixture issue.
The distributor is a used unit and I never had it fully tested. The seller insisted it was in perfect working order. When I received the distributor it looked almost new. So I never had it tested, something I should have done. Does anybody have an 85 930 workshop manual? |
I have the factory manual. I think it covers your year.
Blown,
Can you scan and email the timing section for my year? I would greatly appreciate it. |
I can't scan but I could fax the pages. What do you want? E-mail me with your fax #
