-   -   Cdi tester (http://forums.pelicanparts.com/porsche-911-technical-forum/814532-cdi-tester.html)
boyt911sc 06-17-2014 07:19 AM
Another individual behind a screen name........
Originally Posted by xgnsxgnhu (Post 8120289)
I would love some feedback on what I have come up with so far. http://finanziellede.de/hu6d.jpg
What have you come up that could interest us? Who are you? Never heard you before you popped out!!!!!! Provide some demo.
Tony
dicklague 06-17-2014 03:14 PM
Tony
Yes Tony what and who was that?
Dick
dicklague 06-17-2014 03:15 PM
Originally Posted by timmy2 (Post 8120088)
Just received a tester from Dick to try out for him.
I need to find a spare coil as my old one has mysteriously vanished....?
On first glance the unit is nicely constructed and looks better than the prototype.
I will get set up and test it out on a spare 6 pin cdi I have and report back.
(Once I find my coil.. GRRR)
Find that Coil!!!:D
911s55 07-18-2014 08:17 PM
What's the word guys? Positive, negative?
dicklague 07-18-2014 08:58 PM
Not sure he has tested the model I sent. I have continued test prototypes here, and have done a model that produces a square wave signal at a single frequency that is the equivalent to 2000 RPM.
Also have one with 3 RPMs 1000, 5000 and 10,000 with a rotary switch. And a similar with a variable resistor adjustment.
these would market at different price points in that the variations have more components.
For basic testing the single frequency is fine.
I aim to market one or 2 versions,but at this point I am not sure of demand. Any feedback would be appreciated.
timmy2 07-18-2014 09:29 PM
I'm sorry, I have not been able to test it as I cannot locate my spare coil right now and I need the one in my car.
Will any old coil work? I have one from a '69 GM, just don't want to blow it up with too high a voltage.
timmy2 07-18-2014 10:19 PM
OK in the time it took from my last post to this one I set it up on my 6 pin cdi, used an old GM coil and spark plug and ran the tests.
2 different intensity sparks for 2 different frequency inputs. Added benefit is I now know my spare CDI works. :)
It Lives! (darn good spark for that dirty old plug!) Great tester...
http://forums.pelicanparts.com/uploa...1405747050.jpg
dicklague 07-19-2014 09:36 AM
Thanks Dennis. Do you have a photo of the test setup?
Dick
timmy2 07-20-2014 11:06 AM
Cdi tester
Here you go:
http://img.tapatalk.com/d/14/07/21/e3usame4.jpg
My setup isn't pretty, but it works... :)
maninblack 09-24-2020 11:10 PM
Did this ever come to fruition I wondered as I looked a shelf of old CDI's...
maninblack 09-24-2020 11:14 PM
Actually, just found Dick's website and ordered one.
boyt911sc 09-25-2020 04:19 AM
CDI tester........
Manin,
Could you share with us what you got? Interested in getting one too. Thanks.
Tony
blucille 09-25-2020 05:07 AM
Here you go...
IG3TECH
47silver 09-25-2020 01:48 PM
77911
You mention the trigger signal is reversed, would that mean that the dwell is the remainder of 60 -xx. For example a 1972 dwell i think is 38 with a cdi. Would we then set up msd dwell to 22?
ischmitz 09-25-2020 01:56 PM
Dwell is not important for the simulator. The 3-pin CDI will release its spark at the exact moment when the points open. The simulator most likely has an IGBT or MOSFET that switches on and off with at the given frequency and a certain duty cycle. Once the device turns off the spark is triggered regardless of whether the duty cycle of the signal is 60/40 or 40/60.
Ingo
