In maintenance phase
daniel911T's Avatar
Question Seeking advice on track/autoX wheels - '69T
Hey there Pelicans!
I've been working on my car for a long time, and you've all been super helpful, thanks for everything!
I've just started autocrossing out here in CA, and I'm loving it. I've made some suspension upgrades, but I've kept it pretty simple so far. Here's what I have right now:
Front:
Torsion bars: 18.8mm (stock)
Sway Bar: 15mm (stock)
Shocks: Koni housings (stock) with koni inserts from a '87 930
Brakes: stock M calipers
Rear:
Torsion bars: 26mm (930 stock)
Sway bar: none
Shocks: Koni Classic hydraulic (stock)
My factory 14 X 5.5 Fuchs severely limit my tire choices. I'm pretty confused by all the various widths, offsets, and availability of good rubber.
Can you please suggest a set of wheels that meet the following criteria:
1. Fits without modification.
2. Has a good selection of track / performance rubber.
3. Is readily available and inexpensive. (like a base Boxster wheel or something)
4. Appearance is unimportant - these will be track wheels only.
5. Anything that will fit is ok - 944, 928, watercooled, etc...
Thanks!
1969 911T (Getting a 72E heart transplant)
2004 Volvo XC70
Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s.
Old 06-05-2014, 01:20 PM
Home of the Whopper
15x6 or 7 cookie cutters.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 06-05-2014, 02:49 PM
This..
Old 06-05-2014, 03:13 PM
daniel911T's Avatar
I'm still open to suggestions, but at the moment I'm officially looking for a set of thrashed cookie cutters.
What size rubber?
2004 Volvo XC70
Old 06-05-2014, 03:53 PM
bgyglfr's Avatar
205s fit well with a narrow body. You could squeeze 225s in there but it might require some camber adjustment in the rear. I have a set of 15x7 cookies and they fit fine.
70T 2.7RS spec.
68L coupe
Old 06-05-2014, 04:00 PM
RETIRED
Joe Bob's Avatar
Autocross, which ain't real racing, is designed to improve your street driving skills. Run what ya brung.....changing wheels will get to be a pain in the ass. Just my experience and I was a Zone 8 champ for two straight years.
2012 ML350 3.0 Turbo Diesel
Old 06-05-2014, 04:31 PM
Under the radar
Trackrash's Avatar
There are some considerations to be made.
If you just want to have fun, tires don't matter.
If you want to compete, it gets complicated.
Take some time and see what TIRES others who have long hoods are using.
In autocrossing it's all about tires and classes. I'm assuming that is a PCA autocross?
If you want to get serious, read the rules and decide what class you might want to run in. In other words, what mods have you made that will affect what class you would run in. BTW, I'm not sure what the heck zone 7 is doing right now with their classes!
For wheels, 7 x 15s will probably be your best bet. Anything that fits a torsion bar 911 will work. So forget any newer model wheels. On a budget cookies are your best bet. Replica Fuchs would be great IF you could find 7 x 15s.
205 50 tires are probably your choice. Now you must decide how soft you want to go.
BTW, I change to my dedicated autocross wheels before every event. Not a real problem for me.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-05-2014, 07:22 PM
daniel911T's Avatar
Run what you brung looks like this.
The 14" wheels and crazy soft stock suspension were not ready for any kind of aggressive driving. It's getting more fun now.
I'm also hoping to get a bit of track time while I'm near Laguna Seca.
2004 Volvo XC70
Old 06-05-2014, 07:31 PM
