-   -   68 911L running issue (http://forums.pelicanparts.com/porsche-911-technical-forum/814859-68-911l-running-issue.html)
vwmann1 06-10-2014 06:44 AM
I'm fairly sure the ignition is good. Everything is new: box, coil,distributor, cap, rotor, wires, plugs. I am going to put in the NGK plug Paul recommends instead of the Bosch in there now. I have not checked the fuel pump pressure or accel pump volume. I will check those next and get back.
