-   -   Stupid question about jacking the front of the car. (http://forums.pelicanparts.com/porsche-911-technical-forum/815024-stupid-question-about-jacking-front-car.html)
sugarwood 06-07-2014 01:02 PM
Apologies for doing this, but I just read every jacking thread ever, maybe 30 or more.
I still have a very stupid question.
The Pelican photo says to jack the FRONT by the "A-arms" but the photo is ambiguous to me.
Is the jack positioned under the big thick diagonal arm?
If you jack under the diagonal arm, it seems very unstable for a flat jacking pad.
Wouldn't it make more sense to stack 3 blocks on the left side, and 1 on the right to simulate the diagonal surface?
Or do you jack from that flat section with 2 bolts ...behind and to the left?
Thank you for a clarification.
http://www.pelicanparts.com/techarti...small/Pic4.JPG
safe 06-07-2014 01:15 PM
Behind the a-arm, that's the easiest.
You could also jack on the front a-arm mount, but that's more difficult.
I usually jack in front of the gas tank in the middle, but I have made a piece of iron to spread the weight, otherwise that's not a good idea.
sugarwood 06-07-2014 01:22 PM
Thanks for your reply.
So, where the 2 bolts are?
Just jack there for starters?
Anyone have a photo of the front a-arm mount?
Why is that harder to jack from?
safe 06-07-2014 01:35 PM
Yes, where the 2 bolts are.
You can't miss the front mount if you look under the car. Its harder because you usually have the front rubber lip and you can't get a jack in there.
A tip is to get a pair of 2x8" (or something like that) pieces of wood to drive up on, that will give you some more room.
SilberUrS6 06-07-2014 01:39 PM
I am now starting to see why I need a low-profile jack. My jack is only barely low enough to lift on the sump plate (with a magazine as a cushion - I think the next time I do it, I'm going to buy a Cosmopolitan in Ronnie's honor, for the express purpose of using as a sump cushion.)
For reference on your question, I use Pelican's jack plate, my floor jack, and when the car is high enough, I put a jack stand under there, at the body lift point nearest where your pictured jack pad is. Then I go to the other side of the car and do the same thing.
manbridge 74 06-07-2014 04:14 PM
I'd suggest the uni-body seam somewhat behind and to the outboard side of the pic. Use a wide pad to spread the load and you'll be doing what all us service techs are doing every day on lifts all across the country(USA)...
sugarwood 06-07-2014 05:29 PM
This jack works great
Wait for a sale or coupon, and you'l get it for $80.
sugarwood 06-07-2014 05:31 PM
Jack from these points at the corners that are behind the front wheels, and in front of the rear wheels?
For some reason, this seems milder on body flex tan using the jack hole with Pelican adapter ....
http://www.francistuthill.co.uk/CMS/...0point%201.jpg http://www.johndglynn.com/wp-content...-point-2-1.jpg
911pcars 06-07-2014 05:56 PM
Once you get the car jacked up on one side (jack point or lift location behind the front wheel), slide a 2x4 across the front under the front torsion bar mounts, then position a floor jack midway under the 2x4. Go up from there to evenly lift the front end.
Sherwood
manbridge 74 06-07-2014 06:03 PM
[QUOTE=sugarwood;8104993]Jack from these points at the corners that are behind the front wheels, and in front of the rear wheels?
Yes. But even on earlier models without the pictured "squares with holes" you can lift on the pinched body seam.
Ronnie's.930 06-07-2014 06:08 PM
Eric, unless you are on a low-cost-jack budget (not that type "jack" as we are all well aware that your budget for that is limitless!), stay away from the Harbor Freight, etc, turds and spend more to get a real tool (no, not me). The following costs much more than the HF, but is an extremely high quality piece that I wish I had started using a long time ago.
Amazon.com: Arcan ALJ2T Aluminum Floor Jack - 2 Ton Capacity: Automotive
And regarding your Cosmo purchase, the only way you would buy one of those is if I was on the cover!!!! :D
PS - no offence to the HF jack owners, but I've owned el cheapo jacks and there is a big difference between a turd and a not-a-turd (not just the price difference). :)
SilberUrS6 06-07-2014 07:00 PM
No, I've learned my lesson with HF pre-garbage. I won't buy from them unless it's a single-use item.
That jack isn't too bad on price. I've seen some low-profile jacks that are double that.
I'd buy the Cosmo for the make-up tips. Because you have that schitt totally figured out, and I need to learn how you make yourself look so life-like.
safe 06-08-2014 12:14 AM
If you want a really good jack that's low profile and high lifting, high quality, get the DK13HLQ, AC Jacks - Automotive Floor Jacks, Jack Stands, and Accessories - ACJACKS.com
I'we used one for many years now. I promise, its 549 well spent dollars.
Ronnie's.930 06-08-2014 08:21 AM
No make-up here - just all natural sexy, bub!!!!
