-   -   Bilstein shocks (rear) - delete thing? (http://forums.pelicanparts.com/porsche-911-technical-forum/815037-bilstein-shocks-rear-delete-thing.html)
Flojo 06-07-2014 02:39 PM
Hello!
To finish up my chassi update, I today received my Bilstein B6 shocks (24-009751).
I was told to delete this "thingy"... what is it supposed to to, if kept?
Or is it just for transportation purpose?
http://forums.pelicanparts.com/uploa...1402177052.jpg
here's mor pics of the pair just for fun as they are so new and bright :D
http://forums.pelicanparts.com/uploa...1402177095.jpg
http://forums.pelicanparts.com/uploa...1402177112.jpg
http://forums.pelicanparts.com/uploa...1402177126.jpg
JAR0023 06-07-2014 02:50 PM
Spacer for the bump stop. If you are at 'euro height' or less then leave it out. -J
Sent from my HTC One using Tapatalk
Flojo 06-07-2014 02:53 PM
ah, OK. makes sence.
I'm 1cm below euro ;-)
dipso 06-07-2014 02:55 PM
You will have less shock travel if you keep it. I think I threw mine out and cut the bump stop 'accordion bumper'. But my car is very low.
What you can do is remove your old shocks and measure the bump stop material on them. If your shock travel is good right now, reassemble with the new shocks with the same amount of bump stop material. If you want a little more travel, either remove the big thing you are pointing at, cut the large top off of the bump stops off at the groove or both.
I would probably at least throw the big stop you are pointing at, away.
manbridge 74 06-07-2014 03:39 PM
I would put it in the file labeled "crap can."
Flojo 06-08-2014 08:38 AM
OK, thanks
SoCal911SC 06-18-2014 12:07 PM
Don't mean to change the topic of your thread Flojo, but I'm getting ready to replace my rear Bilsteins also and it looks like the passenger's side rear is a real pain to get access. Any tricks to replacing that one? Thanks.
Matt
Robey5 06-18-2014 12:14 PM
SoCal:
I replaced my shocks with the engine out making it rather easy --- however --- I would suggest that you pull the heater tubes FIRST so that you can see the bolt to hold the shock in place. From there, with the rear of the car in the air - I am sure that you will be able to do this job in about 30 minutes. I know these bolts have nylon thread locking in them, but I added a bit of lock-tight red to be "extra" sure that they weren't going to be departing their rightful position after they were hit with a torque wrench.
Dumb question: Why does bilstien use yellow some times, and green in others?
Is that associated to the different dampening properties (ie: stock/base model versus "sport" model)?
Flojo 06-18-2014 02:37 PM
Matt, its all easy even with the airbox in the way.
For removal, give the nut some sosking time with wd40/caramba.
I was lucky, as it came right off.
For installing, the allen grip of the Bilstein makes it easy and you can secure it from top.
My swap took 20min both together.
SoCal911SC 06-18-2014 02:53 PM
Oh that's encouraging. I reached back there and thought it was going to be a nightmare with visions of removing the CIS and all. Thanks again and I'll let you know how it goes.
As for the other question, I have no idea why the new Bilsteins are yellow. I bought a slightly used set from another Pelican and they're green housings. Go figure.
Peter Zimmermann 06-18-2014 03:11 PM
Bilstein "Yellow" = Sport
Bilstein "Green" = HD
wacko 06-19-2014 10:41 AM
Bilstein "Yellow" = Sport<br>
<br>
Which is stiffer, sport or HD?
SoCal911SC 06-19-2014 11:09 AM
I believe Sports are stiffer.
tobluforu 06-19-2014 12:48 PM
Sports are, and HD's are stiff as hell as well.
