-   -   Both turn signals on constantly when lights are on (http://forums.pelicanparts.com/porsche-911-technical-forum/815131-both-turn-signals-constantly-when-lights.html)
tdskip 06-08-2014 11:14 AM
Obviously not the way it is supposed to work, but since it wasn't always like that and I haven't moved any wiring connections so I am wondering if this is actually in the turn signal/high and low beam switches on the steering wheel. I seem to remember seeing something about this on the forum some time ago. Any tips to pass along?
Thanks.
Joe Bob 06-08-2014 12:47 PM
Swap relays?
chirp 06-08-2014 01:37 PM
Check the bulbs.
tdskip 06-08-2014 06:15 PM
Joe - swap relays as in change the wiring routing or replace the actual relays?
Chirp - may be being dense here but how would the bulbs account for that.
Thanks for the responses.
Joe Bob 06-08-2014 06:19 PM
Turn signal/flasher relay. Do the hazard flashers work?
Porboynz 06-08-2014 09:29 PM
Its always the earth, most of the time.....
cabmandone 06-09-2014 03:54 AM
Sounds to me like you've got a ground problem. I'd check the grounds on your intake, the heavy ground under the car and the ground lug for the battery in the trunk area. It could be a bulb too. I had a bulb blow on my trailer one time that threw my entire brake system out of whack. I can't explain how but somehow it grounded caused all sorts of problems.
tdskip 06-09-2014 06:48 AM
Hazard flashers do work properly in isolation (meaning if you turn them on with nothing else on they work properly).
With the above test confirming they work OK, wouldn't that rule out a ground issue?
Thanks guys.
