Where do you get these headlight lenses???
I'm trying to find some of these yellow headlight lenses. I have checked with Pelican and they don't have them. Any Ideas??
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 09-18-2002, 06:30 AM
Senior Member
They are used in France and Belgium. Have seen a few on the road here in the states but not often. Also have seen one or two for sale on Ebay but rarely. If you know someone in Europe I would bet that they could come up with a set a lot easier than here in the states.
joe
Old 09-18-2002, 06:41 AM
Cool
I would try Dan Stern Lighting....
http://lighting.mbz.org .......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-18-2002, 06:57 AM
gregk1's Avatar
Try sprint-star@t-online.de I got a set from this guy in Germany His name is Thomas, Hope this helps
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 09-18-2002, 07:05 AM
All, Thanks for the responses!!! I just e-mailed Dan and we'll see what that brings. I will e-mail the thomas in Germany too.
Cheers, James
Ayrton Senna
1993 964 RS
Old 09-18-2002, 07:08 AM
curtisaa's Avatar
Yellow lenses...
...Jeez, after seeing that picture I ran out to the garage to see if my car was missing...? That car looks exactly like my car here in LA..
Old 09-18-2002, 07:49 AM
RETIRED
Joe Bob's Avatar
Yeah....but are yellow lenses a flag for the Gendarmes to pull ya over?
Just called the local CHP and they said it's a definite no-no in California....
Old 09-18-2002, 08:26 AM
RSupdate's Avatar
First, they probably would be deemed as illegal here in Cal. but "So far..." I have not heard of anyone of the boyz (RGruppe that is...) having gotten a citation as a result of having the yellow lenses.
But then again I have spent a very considerable amount of time going thru all the c.v.c's (ca. vehicle code) reg's pertaining to vehicle lights, specifically forward illuminating lights.
In a nutshell, the cvc only states that all forward facing lights must be either white or yellow. I could not find anywhere in the cvc where it specifies WHICH lights must be what color !!!
If anyone can find this it would be great, cos I sure can't.
As it is now it seems as a kind of loophole of sorts
But It won't put me off.... I like 'em and intend on putting them on my ride...my luck I'll be the 1st to get pulled over too..
Hey Sam...my $$$ is burning a hole in my pocket!!!!
Johnny Riz
1973 911 Custom Euro 3.2L "Sports Purpose"
'10 Subaru WRX-STi Hatch - modded.
RGruppe#152
Early 911S Reg.#335
Old 09-18-2002, 11:06 AM
skinnerd's Avatar
One thing that you'll notice with the guys that have the yellow headlight lenses is that they all seem to have a set of clear lensed driving lights as well (just like the black car in this post). My buddy up here in Oregon that has a set of these tells me that if he ever gets pulled over, he just says that the clear lensed driving lights are his "headlights". Seems like this could be a workaround. One thing I've been told is that these yellow French lenses only work in H1's and not in H4's. I guess this should be confirmed as well.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 09-18-2002, 11:16 AM
MMARSH's Avatar
Performance products has the lens for $79.95.
H4 part # 912964
H1 part # 912966
Michael
Old 09-18-2002, 01:28 PM
You might want to take a look at this old Pelican thread:
Yellow lights in California..
-- Curt
Old 09-18-2002, 02:15 PM
usurpah's Avatar
Hi,
Newbie question here, but are those 7 and 9" Fuchs? Or 7 and 8's?
Thanks,
- Eric
Eric C
'88 911
'14 Cayman S
Old 09-18-2002, 02:21 PM
Whose car is that? It's beautiful. I love the driving light look. Basically everything about that car is spot on.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 09-18-2002, 02:26 PM
Early_S_Man's Avatar
Porsche Crest
Just for the record ... the yellow lenses are designed for Bosch H1 headlamp assemblies, ONLY! Yes, they wil fit on an H4 assembly, but the beam pattern will NOT be correct!
The 'official' Porsche solution for the French market with H4's was a yellow-tinted H4 bulb ... per the 1972-73 Parts Catalog!
While I have not examined the output patten of an H4 headlamp with an H1 lens installed, several Pelicanheads have reported terrible lighting patterns when the incorrect lens had been installed by previous owners! In some cases the Bosch headlamp assembly was badmouthed ... by individuals wanting a 'better' solution! It was not until some of the H1/H4 ID 'points' that did not jive ... was it determined that the incorrect lenses were the problem!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-18-2002, 02:34 PM
RSupdate's Avatar
H4 part # 912964
H1 part # 912966
Yes, you are correct, But if one compares the two, you will immediately notice that the yellow lenses that Perf Prod sells are a muddy, opaque sort of yellow, I suppose because they are plastic.
The Euro Bosch & Hella lenses are glass and have a very crystal clear yellow appearance. Note the high clarity of Curtiss' lenses in the pic abv, and then compare with the pic in the PP catalog, I saw both this last weekend at Autofest, the difference is profound.
Johnny Riz
RGruppe#152
Early 911S Reg.#335
MIK911's Avatar
Anyone have more/other pics of these yellow lens on cars?
thanks
mike
Old 09-18-2002, 04:59 PM
dtw dtw is offline
GAFB
Balls! And here I just dropped coin on some fine new yellow lenses. Well I guess there's only one true solution for my lack of correct lamps. And I DON'T mean selling off the yellow lenses, Muhah!
Several BMWs
Old 09-18-2002, 05:16 PM
Porsche Crest
Dave,
Good luck on your quest for H1's ...
There are some occasional good deals on eBay ... last year I picked up a very good single H1 unit for a spare ... for $90.09 plus postage and money order fee! The catch was that the ad title said it was a Hella H1 headlamp ... so I'm sure many searches misses it if looking for 'Bosch H1 headlamp,' so keep an eye out for 'Porsche H1' or just 'H1' and you might get lucky!
Warren Hall, Jr.
Old 09-18-2002, 05:36 PM
nostatic's Avatar
Your car might be in the garage Curt, but you'd better hope that photo didn't steal its soul.
However judging by the drive back from Autofest, I'd venture a guess that it is still intact
Old 09-18-2002, 05:47 PM
They would be legal in Berkly CA. . Every thing is legal there.
Jerry
Old 09-18-2002, 06:25 PM
