Engine Fuse box
Hi Gang
I need an Engine Fuse box cover for my 71 911. Will any year cover fit? TIA |
They are slightly different on later models, but will work. The wiring harness is different on the later cars, and comes out in front instead of the back. But any year should work, if you aren't concerned about period correctness. You may have to trim a later one to clear the harness in the rear.
| All times are GMT -8. The time now is 10:48 AM. |
