-   -   Need a part number - A/C center vent (http://forums.pelicanparts.com/porsche-911-technical-forum/81553-need-part-number-c-center-vent.html)
steve911 09-22-2002 02:23 PM
Can anyone tell me what the part number is for the center AC vent for an '85 Targa? (the dash vent)
TIA
RatBoy4 11-29-2002 12:21 PM
Not 100% sure but I believe it is 911 571 067 02.
Dan Owens 11-30-2002 07:28 AM
Steve,
Noticed your post and was wondering if you need a replacement center vent? If so which parts, the whole thing or just the 2 air deflectors that fit inside the vent?
Dan O
cary 11-30-2002 10:51 AM
Steve, I don't have the #. But there are 2 kinds. One with the lever to close it off. And one without.
I believe the one with the lever is the A/C one.
steve911 12-12-2002 12:21 PM
Cary--
Thanks - how are you healing?
Actually, I think there was a change in the vents 86+ for both the center vents and the side vents. (I have an '85). The newer center ones have the on/off, while the older ones do not, and the side vents are MUCH larger, though they can't (I believe) retrofitted to older cars.
Tool Pants 12-12-2002 10:23 PM
2 vent part numbers are listed depending on if you have a/c or not. 911-571-067-02. If you have a/c then the part number ends in 03 instead of 02.
Jeff
