-   -   Front Koni Insert install # 86 1942 - gland nut does not tighten all the way down? (http://forums.pelicanparts.com/porsche-911-technical-forum/816075-front-koni-insert-install-86-1942-gland-nut-does-not-tighten-all-way-down.html)
93nav 06-13-2014 05:27 PM
Hello,
Doing the install of front Koni inserts in a 1976. Old inserts came out fine (what a mess). New insert goes in, but when tightening the gland nut, it does not seem to tighten down all the way (to the bottom). See pics. Or is this a normal height after tightening? There is a little more tightening to go, but not much. Is the new insert to long? Without the insert in, the gland nut threaded all the way down in the lower housing.
Did empty out all the oil and fish around the bottom of the lower housing with a magnet and hooked wire, nothing.
I did see a mention in another post (old) that the gland nut needs to be tight, but may be a little above the lower housing when it is.
Part number 86 1942
http://forums.pelicanparts.com/uploa...1402705101.jpg
http://forums.pelicanparts.com/uploa...1402705163.jpg
Old vs New
http://forums.pelicanparts.com/uploa...1402705210.jpg
Old vs new bottoms
http://forums.pelicanparts.com/uploa...1402705260.jpg
Arne2 06-13-2014 07:10 PM
I've not done any 911 struts, but that is totally normal on other insert types. If the gland nut bottoms out, it won't hold the insert tight.
Trackrash 06-13-2014 08:17 PM
True, the nut will not completely bottom out. Just make sure it is TIGHT.
93nav 06-13-2014 08:57 PM
Thanks for the responses, just the info I needed.
