I am guessing that 8 broken head studs is a bad thing?
I just acquired a 78 SC with 35,000 miles on it and no rust for a good price and was feeling pretty good about it. It was a barn find, but it started up and seem to run ok. I only drove it about 10 miles and decided to go through it with a valve adjust, new plugs, oil change, trans oil change, check ignition timing, new distributor cap and rotor.
Today, pulled the valve covers to do the valve adjustment and these fell out of the lower covers. Nice pre-Father's Day gift. Nevertheless, I have 90% decided to do as much of a top end job myself (never done one before) as I can and put in a set of steel studs. While I am in there, I can clean things up, fix the 4 pulled valve cover studs and put in new Carerra chain tensioners. Here is my question, with 35,000 miles on the engine, does the fact there are 8 broken head studs in and of itself indicate that other serious problems exist that I should be prepared for before I dig in? Bradhttp://forums.pelicanparts.com/uploa...1402781805.jpg |
blown head gasket rings, cylinder grooves, valves ??
they can pop just from sitting a long time. i fixed an '81 that had 6K miles and 6 broken studs. so you may not have much cylinder to head damage. never know until it's apart.
Thanks. That makes me feel better. Now to drop the engine and dig in.
Good luck on the long broken one...
Bruce |
Yeah, I was thinking the same thing.
Where are you in VT?
Is the mileage on the car correct ? Seems like a lot of studs for a 35k mile motor ? That's not that many miles / heat cycles
I just finished a rebuild, http://forums.pelicanparts.com/porsche-911-technical-forum/752699-vermont-first-engine-drop-87-targa.html never did it before but learned a ton. Ended up dropping the motor twice. Would love to help, but you are pretty far South. |
Whiz and Kodi,
Wow. Thanks for offering to help with my new project. That is very nice of you. I am located in Brattleboro, so that would be somewhat of a trip for each of you. I have done one engine drop previously on my '73 (with my son helping) and it went pretty well. But, since then, I got distracted on some other things and never got around to the engine teardown stage on the '73. Then, this '78 came along . . . . This time, my plan is to drop the '78 engine and move forward to pull the head, check things out (hopefully, no additional evident problems) -- install the Carrera chain tensioners, clean up and powder coat some stuff, clean up the engine bay and put it back together. The place I think I could most benefit from help would be pulling the broken studs -- but would be grateful for help at any stage. I don't own an engine yoke or engine stand, so those are next on the buy list. If you have either and want to sell them, let me know. I am not sure on timing going forward but would like to get the '78 back on the road before the end of summer. If you would like to "be invited" to the party (dropping the engine, pulling studs, whatever), please send me an e-mail and we can keep in touch that way. My e-mail is bfawley@drm.com. |
If ur up for a drive I could loan you the yoke and the stand.
Seriously! That is very generous. Wow, that would be fantastic. My son actually lives in Burlington and is coming down to Brattleboro on Wednesday. Is there any chance he could pick them up from you before then?
Brad |
The most 'serious' engine work I've done was dealing with a head stud issue. I put the engine on a yoke, disassembled one side of the engine, fixed the problem and reassembled. It's fiddly business and you need to measure at every stage, but it is something you can absolutely do in your garage.
I had always heard that the 3.0 head stud breakage was due to excessive heat cycling (many short trips). But now, 30+ years out, corrosion gets at least some of the blame. |
My 84 with 72K on it had 7 broken studs from sitting for 7 years. Pulls the heads off, fixed all lower studs with new steel, cleaned, measured, put it all back together, runs like a top. You should be able to do it all in 3 weekends.
To all. Thanks for the information and encouragement. As near as I can tell, this car has been mostly sitting for the last 7-8 years. Tires date from 1992! Just a guess, but since it ran fairly smoothly when I started it up to heat the oil prior to oil change, I suspect it does not have many miles on the broken set of studs. No popping on acceleration. Time will tell.
I LOVE the idea of 3 weekends of work -- but would not even mind if it took 8. I will post my work as I go. Should be an adventure. Brad |
Maybe 8 is better than 1.
If you had one you might try to convince yourself you didnt have to tear the motor down. Optimistically, Aschen |
I had one broken head stud, 3 years ago when I got my car, dove in right away, broke 2 more taking it apart.
Put it all back together within a month. Now it has new studs, gaskets, chain ramps, hydraulic tensioners rings camshafts, heat exchangers, muffler etc. been good to go for almost 3 years now. Bought a lot of specialty tools with the money I saved doing it myself, including a mid rise lift too! |
no popping on acceleration with most of the lower studs broken? hard to imagine.
I bought a 78 SC with 8,484 miles. It was last licensed in 98 or so. Had the popping sound and all 12 exhaust head studs were broken. Engine was removed in less than 4 hours and dissembles that weekend. Hardest part was getting the broken studs out. Use heat and vice grips. Hopefully enough left to grab. No other damage. Put in upgraded tensioner. Once I had all studs out and all gaskets in stock, I spent about 35 hours re assembling, measuring, installing etc. I would remove the transmission with the car. Be sure to use Locktite on the axle shafts to transmission flanges. Ask me how I know.
Ask many questions. Folks on the board are great! |
New schnorr washers and running small rags through each hole, last one with brakekleen on it so the bolt threads don't pick up CV grease works as well. I think backed out bolts are mostly due to greased threads and worn washers. |
http://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints-12.html |
Good luck lespaul. If you hit snags there are plenty of 802 Pelican's who can help - I also just completed a top end job in the spring of last year. Plenty of helpful knowledge among members here eager to share.
| All times are GMT -8. The time now is 01:38 PM. |
