Destroyed my 3.2, now what?
Long story short, my 3.2 is toast. Very loud ticking noise and some shavings on the magnetic drain plug?
Rebuild or look into 3.6 swap?
On another note? What would be a fair asking price for the 3.2 without tearing into it?
Old 06-02-2014, 05:13 PM
My best guess is a good 3.2 motor with docs would be 5-7k. I could be wrong.
Old 06-02-2014, 05:30 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Why do you think she is toast?
What did you do to her?
Some shavings is quite normal and ticking? if you mean tappet noise, that is also normal.
Does it turn over when starting or is it frozen?
'85 Carrera Targa
PCA/POC
Old 06-02-2014, 05:32 PM
It turns over and runs I mean a LOUD ticking noise.
Old 06-02-2014, 05:36 PM
Please post a video of it.
Old 06-02-2014, 05:38 PM
Let me upload the video and I'll post the link.
Old 06-02-2014, 05:41 PM
20140602 115238 - YouTube
Old 06-02-2014, 05:52 PM
abit off center
cgarr's Avatar
What's the oil pressure?
______________________
Craig
G2Performance
Old 06-02-2014, 05:55 PM
Oil pressure was very low after it started knocking. As in almost none.
Old 06-02-2014, 05:58 PM
Two or five rod spun..keep running it and the rod comes through the case then it's totaled.
Bruce
Old 06-02-2014, 06:15 PM
MattKellett's Avatar
My guess is you've spun a bearing, the ticking will go away soon.......
In fact there will be no noise at all once it's seized!!
I'm guessing this isn't going to end up cheap!
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 06-02-2014, 06:37 PM
Even worth trying to rebuild cost wise or good time for a 3.6 swap?
I'm guessing a full tear down and rebuild, depending on how much machine shop work you need - including heads and regrinding crank, will be in the region of 12-15k.
I'm sure others will chirp in quickly if I'm way off base.
The thing is you'd then have a known rebuilt engine, the downside with a replacement is that it's always slightly unknown.
Although the idea of a 3.6 swap is fantastic. I've been build a fantasy car with a 3.6 swap for some years now.
Good luck and let us know how it turns out.
Matt Kellett
Old 06-02-2014, 06:45 PM
Just watched the video, which I should have watched before posting!!!
Sounds way noisier than a spun bearing!
Matt Kellett
Old 06-02-2014, 06:47 PM
Vintage Owner
Jack Stands's Avatar
A rebuild isn't cheap, but at least you know what you have when you're done. Even the 3.6s are old engines these days (the newest ones being about 15 years old).
Regardless, the engine has to come out either way, so it may not hurt to tear it down to see what's going on and what the repair will cost.
How many miles are on the engine now?
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-02-2014, 07:10 PM
Under the radar
Trackrash's Avatar
Sounds like a rod for sure. 3,2s are known to have problems with the rod bolts. I wouldn't even start it again.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-02-2014, 07:14 PM
Thanks for the replies. I'm not sure on the mileage as I bought a sc with a 3.2 swapped in.
Old 06-02-2014, 07:15 PM
It won't be started again. I'll be dropping the motor in the next few days and try to come up with a plan of attack.
Time is not really on my side right now. I'm in the Air Force and am moving next month. I need to ship the car and would like to have it running before then so I don't have to try and find someone to move it not running and pay the extra $$. Plus I'd like to enjoy it some this summer.
Old 06-02-2014, 08:02 PM
The money to convert a 3.6 into a 3.2 might be more than rebuilding your 3.2
I would probably go with two new oil coolers and flush the lines really really well too.
Old 06-02-2014, 08:12 PM
Chain fence eating turbo
Machining and rebuilding next month would take a lot of planning and luck. Took me 2 months to rebuild my 3.2 working 2-4 hours a night and the occasional longer stretches on the weekends.
Old 06-02-2014, 08:44 PM
