-   -   both turn signal arrows lit? (http://forums.pelicanparts.com/porsche-911-technical-forum/816465-both-turn-signal-arrows-lit.html)
rockreid 06-16-2014 12:54 PM
not sure if this is normal or not... I've sorted out pretty much everything I think in my 73.5 Targa restoration but upon Key On both turn signal arrows light up dimly. The turn signals work fine and arrows blink brightly when flashing left or right.. Should the arrows be dark or lit dimly when no turn signal is activated? And if this is a problem is it likely the turn signal flasher?
wayner 06-16-2014 01:12 PM
Bad ground or loose bulb
fritzgator 06-16-2014 02:11 PM
Aftermarket relay caused the same in my SC
Joe Bob 06-16-2014 04:40 PM
Blown bulb.....
catuck 06-16-2014 08:57 PM
I would say bad ground. Mine does it too, all bulbs are fine on mine and I have correct relay. I haven't gotten around to finding the ground problem yet but that's what I'm banking on.
RMR73 06-17-2014 05:13 AM
Had the same thing last week on my 73 targa New flasher solved it.
