Check reverse light fuse issue
Rear drivers side tail/brake light fuse(15) keeps tripping on 2007 911 Porsche Carrera S. Have tried changing and swapping same fuses with no success.
Regards, Tom Smith |
Not knowing the late cars but if the 2back up light connection on trans touch because they are not plugged into trans in early car it can blow fuse
Bruce |
New problem or a new car with existing problem?
Swapping in another fuse because a fuse is blown will only waste fuses. The problem won't go away just because the fuse has been replaced. Get a wiring diagram, trace the circuit, and repair the short that's causing the problem. It could be that another electrical consumer is causing the problem. What else is on the circuit?
The Cap'n |
| All times are GMT -8. The time now is 11:36 PM. |
