oil tank cleaning
i am going to install a used oil tank, the tank is in great shape but needs cleaned a painted. i will use wd40 to clean the outside but what should i use to clean the inside (after i remove the sending unit) and what type of paint and color (red?) should i use to paint it
thank g 75 targa |
Crusty Conservative
I'd suggest something good for a harsh environment, like POR-15. It comes in a lot of colors, and is pretty durable. These tanks seem to rust because of the combination of the heat from the oil and small bare spots on the metal exterior due to flying rock chips. etc...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
por-15
hi: i am not familiar with this paint, is there a manufacturer or website that i can find it?
thanks g |
Crusty Conservative
Use toluene to clean the inside of the tank, plug the holes and swirl it around a few times drain then repeat until clean solvent comes out.
POR actually makes a fuel tank kit (inside and outside treatments) - should be on that link.
Cam |
tank treatments
i talked to very knowledgeable distributor today, he recommended the motorcycle fuel tank repair kit which comes with: marine cleaner, metal ready to remove rust coat with zinc, tank sealer all for $27.00 usd semi-gloss black paint kit about $15 usd only concern will the zinc react with magnesium crankcase? g |
fancytown
My concern with a fuel tank kit would be if the sealer is rated for the temperatures the oil would see (250F +???). I don't know if the fuel temps get that high. I wouldn't think it would be necessary to seal the inside of an oil tank. The surface would be coated, and the level would remain fairly constant (compared to fuel). Plus, the sealers might not be compatible with engine oil either. I don't know if this is true, but you might want to look into it if you're not sure.
all cars sold. |
