I'am the proud new owner of a 71E and I need advice on what best to do with the front suspension. It still has the orig. self leveling struts but they seem to be non functional. Whats involved in converting to a S setup and where can I get the parts.
Crusty Conservative
You can check the Porsche parts ads here, and on Rennlist.
You can contact Partheaven in Hayward, CA, a big seller of used Porsche parts. You could place a "parts wanted" ad in the above places. You might try Oklahoma Foreign in OKCity just a few thoughts...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
I have a complete 1970 T front end converted over to Koni Adjustables. I would be willing to sell you the front struts only, for about the price of the Koni shocks plus shipping
let me know... addictionms@hotmail.com |
Upon futher inspection the front struts are Koni part# 911 341 96200. What do I have here??
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
As I remember, the shock manufacturers, koni, bilstein, boge all made the self leveling struts also.
The self leveling strut is larger in diameter than a regular strut and doesn't have a dust shield that slides up and down with the shock shaft. It simply has a bellows located on the top of the strut and attached to the top of shock shaft. Good luck, David Duffield |
Koni built some of the hydro struts for Porsche ...
The required conversion parts in a factory conversion kit are shown below ... A drawing shows the total hydro package at the front end ... including the rubber bellows between strut dust cover and body mount.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
These Koni's have the standerd metal dust cover and no rubber bellows they are also adjustable and are larger in diameter thay the rears.??
Then you don't have to worry about the converstion. You should have everything pictured above, including the regular torsion bar adjuster with 11 mm hex end at the rear of the torsion bars ... for height adjustments!!!
