High oil pressure after changing oil tank
Hi, i have a 71 targa with a 2,7 engine. My original oil tank was broken and i got a oil tank from a 76 SC. I put the new tank in and now my oil pressure is much higher. At idle it shows 2 bar, at 2500 rom it shows 5 bar, at 3000 rpm it shows 6-6,5 bar. This is at normal temperature. When its cold it reads almost 8 bar at 2500 rpm.
I have checked with a mechanical oil pressure gauge and it reads the same. Pulled the oil pressure switch and put a small rod down the hole and i can move the oil pressure relief valve . What is wrong ![]() Michael |
oil pressure is still too hi. i would question the sending unit being compatible with the gauge.
even idle pressure is realistically too hi. the 77 did have a higher pressure pump from the early cars but 2bar (29psi) is not realistic....if your idle is 900-950. mine was betwen 15 and 20 psi at idle. you may have a blockage in the oil path
86 930 94kmiles [_ _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ _] RUNNING: [__] NOT RUNNING:01 suburban 330K:: [_ _] RUNNING: [__] NOT RUNNING:RACE CAR:: sold Last edited by T77911S; 06-25-2014 at 11:19 AM.. |
Interesting. Is it possible your original tank had a blockage? Why did you replace it? Oil tanks usually don't "break."
My oil tank was thin as paper and full of smal holes, PO did try to fix it with plastic padding
you may have something from the old tank clogging an oil passage in the engine.
a sticking pressure relief would only allow pressure to build past the relief point, not increase pressure at say idle. you could also have a relief problem if your pressure is going as hi as you say it is. i know on my 77 when it was cold in the winter my pressure could go above 100psi. i drove it very easy to keep it below that until warm. did nto want to blow oil cooler.
The pressure was fine with the old tank, it was after i put the new tank in i got the problem
