normal oil pressure
I am worried about my oil pressure. While driving around I notice it never really gets above 3 bar (all gears upto 6K rpm). However, at idle it only registers under 0.5bar. I had the pressure tested and the sending unit seems to be giving me accurate readings.
What type of pressure should I be seeing at idle and what is the maximum pressure I should see occasionally?
1979 911SC
2003 ZR900
Old 09-26-2002, 08:00 PM
