Idle RPM
How do you adjust idling? What rpm should a 77 911S idle at?
Functionista
950 RPM plus or minus 50.
Large flathead screw on side of throttle body. Out is higher rpm. In is lower.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
