Car driven 500 miles in 7 years. Concerns?
What should I be concerned about with a mid 80's Porsche that has driven under 500 miles in 7 years? The last stated mileage on record is from 2007. Thank you in advance.
Tampered odometer?
varnish in the fuel system dried seals all the way around tires no longer DOT road legal, and hardened moisture in the engine oil mice and rodent occupation likely dead battery brakes could be frozen, but the fluid is definitely shot, hygroscopic properties. the list goes on I assume you have taken possession of the 930?
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) Last edited by Justin@Athens; 06-28-2014 at 03:31 PM.. |
Thank you for your thoughts. No I haven't. Just doing some due diligence while away.
Seals in the turbo can go bad as well, but its probably lower down on the list of things to look after before running.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
