draining oil sump for stud repair
Recently changed my engine oil only to find 2 sump studs are pulled and leaking. If I remove the sump plate to make the repair to the studs how much oil will I lose. Will the oil from the tank drain into the sump and continue to run out? Should I just bite the bullet and drain all the new oil and replace with new, Thanks Jerry
Buy a clean 5 gallon bucket at Homer D. Drain oil into it, fix stud, pour oil back in
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Engine on (I've heard it distributes the oil more evenly) or off?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
