earthtorobots.com
Joshy Robots's Avatar
mounting rear bumperettes on a frankensteined '69
Putting the proper rear bumperettes on my '69 and was wondering what sort of hardware I'll need.
Bolts and washers and whatnot.
I've got the bumperettes coming and a license plate panel on the way.
thanks!
Here's a shot of its current franken-look:
Old 07-07-2014, 01:19 PM
Dan Morton's Avatar
This is a very simple swap and will definitely make your car look a lot better! The rear bumperettes attach to mounts integrated into your side bumpers where your current bumperettes are located. You should double-check that the mounts are still there.
The rear panel would go on first and simply slots into place over these same bumperette mounts.
You will then place the bumperettes and secure each with two bolts and washer per bumperette.
There is also a small nut and bolt that secures to each lower corner of the license plate panel which helps to keep the panel aligned with the side bumpers.
See attached photo that shows the mount for the bumperette.
-Dan
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
1997 993 Targa (sold)
Old 07-07-2014, 01:33 PM
muck-raker
kidrock's Avatar
I would be more than happy to take that roof rack...just helping to "un-Frankenporsche" your ride a little bit.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-07-2014, 04:12 PM
earthtorobots.com
-Dan
guessing it'll all make sense once I get the parts in, but just curious if any of these bits look familiar:
had to kill a man for that rack. make an offer.
Old 07-07-2014, 07:56 PM
