Question How Much Brake Fluid?
I was poking around the frunk the other day and took off the brake fluid reservoir cap to discover that I couldn't see any fluid anywhere. I checked the original '73 owner's manual and there was no mention of fluid level.
The brakes work fine, thankfully. But if I need to add some to whatever level you recommend, what brand/type should I purchase?
Thanks,
Tom
Old 07-07-2014, 03:17 PM
emac's Avatar
Tom I would fill up and bleed all the brakes, also check rubber lines and replace if original. DOT 4 and one qt will do
Ernie
Old 07-07-2014, 05:28 PM
Thanks Ernie.
Tom
Old 07-07-2014, 06:22 PM
76 911S Targa
Make sure when you bleed the brakes that you push the pedal only as far as you normally do when braking. Pushing farther, as to the floor, will likely cost you a new master cylinder.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 07-07-2014, 06:55 PM
ganun's Avatar
Not sure if that year has a booster, but if it does, its very likely thats where the missing fluid went if you can`t find an obvious leak.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 07-07-2014, 07:46 PM
porwolf's Avatar
Here is my brake fluid level:
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 07-07-2014, 09:42 PM
emac's Avatar
Tom is the pedal always firm or at times does it drop down a bit with your foot on it. If so your M/C is bleeding through itself. Just replaced mine this year same symptoms
Ernie
Old 07-07-2014, 10:40 PM
A couple of things affect fluid level. The first is pad wear. As the pads get thinner, more fluid remains in the lines because the pistons are farther out of the bores and there's more room behind them for fluid. The second is leakage, and you need to inspect the open end of the master cylinder under the pedal board, the lines and hoses, and the calipers for wetness. Remember, when you replace the pads you have to retract the pistons in the calipers, and that pushes fluid back into the reservoir. Over filling the system and then retracting the pistons will cause a spill, which you don't want to happen. I recommend leaving a half inch air space in the top of the reservoir once the checking, flushing, and bleeding are done. Do all that BEFORE you top it off! BTW, a good flush and followup bleeding done right should require about a liter.
The Cap'n
Old 07-08-2014, 07:53 AM
Ernie
The pedal is always firm, no slow drop towards the floor.
I appreciate all the advise. Think I'll have the lines flushed and bled properly at our one remaining foreign car shop. And have the pads checked at the same time.
Tom
Old 07-08-2014, 08:15 AM
E Sully's Avatar
Brake fluid absorbs moisture so it is best to completely change it out.
If the brake lines on your '73T are of unknown age, replace them with new dot approved rubber lines, stay away from the SS lines. I would also get rebuild kits for the calipers and change the o rings and dust boots. It is not very hard, just have to pre treat the fittings with PB Blaster or equivalent.
Ed
1973.5 T
Old 07-08-2014, 10:02 AM
Suggest those who insist using the "pump-pedal-and-hold" brake bleeding routine should have one of these somewhere on your property:
Pick an appropriate piece and place under the pedal.
Sherwood
Old 07-08-2014, 10:09 AM
