1985 Carrera
3.2 Ticking sound is driving me crazy!
Well to start, I think I have read every post of issues similar to mine. None of them come to any conclusion but nice to know I am not alone.
First off, engine has no tick when cold. Only once warm. Frequency increases with rpm, but sound doesn't change, still remains as a tick. I have listened to loose cam chain videos, and there is no chain rattle at all. I have also used a screwdriver to listen to the rocker covers and there is no tick coming from them. Every cover sounds the same. I had thought maybe I had bad rocker bushing or broken spring, but assume I would hear it. Now I have also adjusted the valves twice over and same tick remains. I even did it a third time setting them tight, and sound remained. Car drives fine and is smooth as ever. The sound is only really noticeable with windows down driving past cars or walls. It's not audible in the car with windows shut. I ended up suspecting the injectors. With a screw driver to my ear they do sound loud, some worse than others even after a full clean and new screen. I've just been driving it as is and the sound hasn't gotten worse or better. I'm now at the point of thinking to sell it, and I don't want to scare off a potential buyer. Do I just buy a new injector and see if it runs quieter than the others? Then replace the rest? I'm running out of ideas, and am hoping this doesn't require a rebuild to fix! Leak down was 7% average! She's still fresh! Video: https://youtube.com/shorts/BHKm16Gvl5w?feature=share |
Just a thought; have you tried running it for a short time without the fan belt ? Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
You wrote that you've read much but didn't mentioned what you've been done except checking the valve clearance twice..
I had pretty much the same issue on my SC with CIS. Culprit was lean running cylinder due to a too less fuel injected and therefore running too lean and too hot which let the exhaust valve prolonged too much. This caused a ticking sound only when engine was hot. As the Carrera also injects more or less also constantly on every cylinder all the time only varying the duty cycle this could be same reason. Did you measured all injectors already how much they spray and the spray pattern? Did you check the exhaust temperatures in front of the heat exchangers with an IR gun? Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
It’s a different car, but similar ticking once warm. My 996 Turbo has a tick like this. Oil cold (not water related in this car) there is no tick. once the oil is warm you hear a ticking. Changes with RPM, and at a certain point it seems to go away (hard to tell as above 3,000 RPOM there’s a lot of other noise coming up that may mask it). Back in the day Porsche replaced come 996 Turbo and GT3 engine over it (same basic engine). Some people did complete engine rebuilds and had the same noise after. NO one came to a good and well known conclusion. My mechanic, who worked at Porsche’s factory and as dealers here, believe it’s just the wrist pins on the pistons. Occasionally some of them made noise. No real fix, and even when rebuilding a non-ticking engine back in the day, he said you occasionally got a noisy one and the engine ticked after the rebuild when it did not before. Mine has ticked for the 10 years I have owned it. oil analysis shows nothing but a very healthy engine. I even tried thicker oil once. Maxed it stay quiet a little longer on warm up….but once the oil was warm it made noise.
YMMV, just. Just a thought. My 3.2 and 3.6 don't tick. The 3.6 had a similar but different tick, and reapplying my injectors fixed it (I replaced them because one was leaky, not the noise).
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
An exhaust leak can sound like a ticking noise.
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
just a Q.how do you adjust the valves? with a feeler gauge ,or? what is the history of valve guides?
Ivan for you just to compare here is mine https://www.youtube.com/watch?v=Out_PKGkYYY
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 02-13-2025 at 07:51 AM.. |
Long shot….gravel in exhaust.
1985 Carrera
Thomas[/QUOTE] I sent them to a injector cleaner business. He said all were running fine, he did say one needed a bit more cleaning than the others. When I first got the car it was running extremely rich as someone had fiddled with the afm. How would I diagnose a burnt valve without taking the heads off? Or perhaps I should be able to isolate the noise to one bank and position. Reality is, the sound is just everywhere. |
1985 Carrera
Yes, I need to put the car on my lift when I can and get under there. My heat exchangers haven't been changed in decades, so could be something there. I always assumed an exhaust leak sound would do the reverse, be loud at could start and maybe get quieter when warm. I can't rule anything out though, so will investigate.
1985 Carrera
Valve guides, I am not sure. Have no history on any rebuild unfortunately. I know it does not blow any smoke on startup or while driving. Even when leaving it for a month, zero smoke on startup. |
ok.. can you make a video when the engine is cold?It is definitively coming from the valves..
interesting about the franny valve adjustment..that is how i do it past cc.35 years ;-) maybe she saw my video;-).... https://www.youtube.com/watch?v=O_ypBn_u7g8
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
https://www.pelicanparts.com/techarticles/911_backside_valveadjust/911_backside_valveadjust.htm?srsltid=AfmBOorGdZc2k g1tbD-h_LXyf5WJHG4gz8Iq8LR15jRFhW0e1ZaKXan9 I found this method to be very helpful. Even though I used the Kirk tool to adjust my valves (which is pretty accurate) and was super careful, the "go-no go" test described in this article proved that a few of my valves were off. |
Likely exhaust gasket nearest the head. If it had poor leak down I would suspect broken head stud
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Still here
1985 Carrera
1985 Carrera
Cold start no tick video - https://youtu.be/u2f9HUGcSaI?si=Y232LpWAdZW7gC4u
Update, after feeling silly for not trying hard to diagnose it better, I got a long automotive stethoscope and started listening to it once the tick came back when warm. I couldn't hear any exhaust leaks at all. When I listen to the intake cover for cylinder 3 it has this ticking noise. Same noise cannot be heard on the exhaust cover of cylinder three. All other cylinders sound "normal". Cylinder 3 intake, I noticed as different straight away. Next step will be to take the intake cover off. Firstly though, I will cold start it again and make sure this ticking sound is not present, otherwise I might start chasing my own tail. Thing I am wondering is, why only when hot. I am guessing tolerances open up and ticking starts.... might point to rocker arm and shaft? I assume broken springs would make a noise even at cold start. |
yup no sound..yes spring would be noise ...If the spring is broken the larger spring goes 1st.Try to push it in ,the intake 3...Are you using the feeler gauge there or by feel???
How is the surface on the camshaft on 3? Ivan
True, somewhat uncommon on 911’s, but I hear newer Dodge gas V8’s with header leak “ticks” all the time. In my last job we had two new Dodge 2500 pickups that both started to tick like crazy around 20k miles - it sounded like valve train noise…
I doubt you can hear an injector tick. But you can also simply unplug each injector one at a time at idle. An injector without power to it can not tick.
The other suggestion made already is to remove the fan belt and run for very short amount of time, 30 seconds or so to see if the tick goes away.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
