Motor compartment sound/heat pad 1980 SC
My pad has fallen down and I want to remove it - I may replace it later. It seems to be mostly in one piece, the glue has failed and the pad dropped down.
My questions: how is the pad attached on the bottom, can it just be pulled out?
Wayne
1980 911 SC
1960 MGA 1600
Old 06-30-2015, 04:42 AM
KNS KNS is online now
It's just tucked in at the bottom, it'll pull out.
Kurt
Old 06-30-2015, 05:33 AM
wayne robson's Avatar
sound heat pad
Wayne go to, What did you do to your 911 today,
link 4373
page 219
may help,regards.
Old 06-30-2015, 06:36 AM
That is a messy job. When you pull it out dry foam gets everywhere. Put a drop cloth over your engine to make clean up easier.
Scrape off as much of the old foam as possible from the bulhead before installing a new one. Use high heat adhesive.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-30-2015, 09:55 AM
Thanks for all the info!
Wayne
1980 911 SC
1960 MGA 1600
Old 06-30-2015, 03:17 PM
When I went to pull out the pad I realized that it seems to be in one piece... This got me thinking - can it be reattached without dropping the motor? Am I barking up the wrong tree and should probably not deal with the old pad? At a crossroad and need to choose a direction - your thoughts appreciated.
Happy 4th to all.
Wayne
1980 911 SC
1960 MGA 1600
Old 07-03-2015, 05:27 AM
Get rid of the old one, it'll only continue to disintegrate.
I replaced the pad when I had my 1980 SC. I just did a partial engine drop of a few inches(maybe four or so). scrape off all the old stuff, cover the engine with a blanket as mentioned. A new pad looks so much better.
Kurt
Old 07-03-2015, 10:02 AM
Sound pad removal........
Wayne,
If the old sound pad is beginning to disintegrate, remove and dispose it. Don't worry about the mess it will drop on the engine. Pull it up and out. Then use an air compressor and vacuum cleaner to collect and remove the dust/dirt.
An engine partial drop would give you more room but not required to removed it. Installation is completely different with the engine installed. Good luck.
Tony
Old 07-03-2015, 10:33 AM
Send a message via AIM to fintstone
I removed the old one and installed a new one in my '74 without even a partial drop.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-03-2015, 10:39 AM
OK - I'm convinces - it is comming out. Any issues using the car without this pad?
Wayne
1980 911 SC
1960 MGA 1600
Old 07-03-2015, 11:15 AM
It is even more noisy inside the car.
Old 07-03-2015, 11:18 AM
If it's only a sound issue - then let the flat six music begin :-)
Wayne
1980 911 SC
1960 MGA 1600
Old 07-03-2015, 11:57 AM
midnight911's Avatar
the firewall inside the cabin gets hot and don't know how much of that is due to lack of the pad, but you are in the driver seat so who cares.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 07-03-2015, 01:51 PM
Geeze what a mess :-( Got it out - I think all of it.
Not my luck - had to work at it. Will wait to install new pad.
Thanks again to all. Happy 4th - mine will be a bit noisier ;-)
Wayne
Wayne
1980 911 SC
1960 MGA 1600
Old 07-03-2015, 02:50 PM
