sticking tach when hot
My tach is sticking when the car sits outside in heat. Once the car cools off it starts working again. I read flipping the lens may fix the issue. I can only pull the tach out about an inch or two before it hits the wheel column. Does the outer bezel twist off? Anyone know how to flip the glass quickly without removing the steering wheel and column cover? Thanks.
Brian
Ambitious Outsider
1988 3.2 Cab 2005 997.1 C2S |
Home of the Whopper
What year car?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Might be a CDI problem.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
1982. Seems like needle it hitting glass once the car heats up. Of you tap the glass the needle will move. After driving and cooling the car down it will start working again. Always works when car is cool and in garage.
I searched here and rennlist and saw someone else had same issue. They said they flipped the glass. I pulled the tach out as far as poss, but wasn't sure how to get the front off.
RETIRED
Best to have it rebuilt by a speedo/tach shop. Too easy to booger up the bezel with out the right tools or expertise.
I had my speedo done due to a back plastic gear. $110 and an hour of wait. Or you can ship it. You can google speedo shops n your area. Not rocket science.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 07-13-2014 at 07:13 PM.. |
Anyone know of a shop in Ct that may do this on the spot?
Ambitious Outsider
Like the guy's stated above, just contact either of these places. don't waste your time anywhere else.
North Hollywood Speedometer and Clock Company. Serving your gauge needs since 1955. VDO, Porsche, Mercedes, BMW, Volkswagen, Veigel, Veglia Palo Alto Speedometer: Repair, Restoration, and Sales of Automobile Gauges
