puddy's Avatar
Carbon fibre RS style door cards
I decided to replace my ugly beat up stock door panels. They're warped from 40+ years of use and have big ugly speaker holes that hold no speakers.
So I bought the hardware kit from Appbiz and the kit & pattern was great. I wanted to do something a little different than typical vinyl door cards. I happen to have a neighbour who plays with carbon fibre. So I had him make me up 2 rectangular panels for $160 that I could cut down to the shape of door cards and have some bits left over for other small random things. The panels didn't turn out as I'd hoped, the weave and resin was not very uniform but I figured they look better than what I had anyways.
I didn't anticipate that cutting the panels would leave frayed edges from the carbon strands. I found that a jig saw worked better than a dermal tool for cutting. Either way in the end there is still fine frayed edges. So I'm going to try to find a nice small rubber edge cap/ trim to hide this or possibly remove the panels and give them another coat of resin. Some day. But for now they will work.
So this is how they turned out. Probably a lot of money to spend for something that doesn't really save a lot of weight compared to other door cars materials. But I like the look of carbon fibre so I'm satisfied with how they turned out.
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 01-29-2017, 03:14 PM
somoney311's Avatar
I like that look.
James
1989 Slate Grey 930...sold
Looking for the next one!
Old 01-29-2017, 04:56 PM
McMaster-Carr online has a bunch of rubber edging that would work.
Cool look, but the consistency of the weave would drive me nuts.
'82 911 SC
IG: @rywats
Old 01-29-2017, 05:49 PM
Looks great!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 01-29-2017, 05:55 PM
puddy's Avatar
Thanks I'll check their site out.
I agree the pattern will probably bother me. I had 2 pieces and 1 was worse that the other. I should have planned things out better ahead of time and used the better piece on the drivers side.
Cheers, Chris
1986 951
Old 01-30-2017, 01:54 AM
Wer bremst verliert
JohnJL's Avatar
GT racing sells those too.
Next time, or for others working with cf...a wet tilesaw with a standard diamond blade cuts cf like butter and no chipping or frayed edges.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 01-30-2017, 02:48 AM
puddy's Avatar
Cool thanks for the tip!!
Here the GT racing link for those that don't want to itch from carbon fiber strands.
911 Door Panel in Carbon Fiber Part# 20P
Cheers, Chris
1986 951
Old 01-30-2017, 03:11 AM
300hp 1800lbs is the goal
pksystems's Avatar
Thin cutoff disc on an angle grinder worked great for mine. Then wetsand the edges. Your panel doesn't look very glossy. Did you use enough resin?
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 01-30-2017, 03:45 AM
Elombard's Avatar
They look good. For me CF is a modern material for modern cars...say 2005 and later? I would cover those with vinyl or leather. Get some sound absorption and look period correct. Some careful work with 3M trim glue/spray and a piece of backed material and they would come out great.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-30-2017, 03:59 AM
puddy's Avatar
I think my neighbor who made the panels used only 2 layers of carbon and didn't use alot of resin, I would prefer them to be glossier looking but i'll live with them as is for now. Afterall my car is mainly track car, not intentionally but I did the math a realized I put more kms on at the track than on the street. So i don't expect perfection. So its all a learning experience and i'll know what to do and what not to do next time.
BTW I tried a small cutting disc on a dremel and its created a lot of dust for me. But i'll try wet sanding the edges and see if it cleans them up.
Cheers, Chris
1986 951
Old 01-30-2017, 06:04 AM
