CD Player Help
I have a Blaupunkt X-Line Key Largo DM2000 CD player in my 911. It has a flip down faceplate for the CDs. The problem is that it seems that the faceplate is not tight enough, because the lights and numbers and stuff do not light up unless you push the faceplate down on it. It has been this was since I bought it a little while ago. Is there an adjustment or something that I can do to make it tighter or something? Any help would be great!
Take it back and swap the face. If no good, swap the whole thing, the contacts are bad. Don't try to fix / bend them if you can just get them to trade it out.
rjp |
You might trying cleaning the contacts with a small nail file and some rubbing alcohol.
| All times are GMT -8. The time now is 06:51 PM. |
